New Reply
AC Circuit
Share Thread Thread Tools
Nov7-12, 10:33 PM   #1
AC Circuit
Recently, I've been studying AC circuits and have developed a couple questions. I think I worked out an answer to the first, but I don't know about the second.
First, since light bulbs in houses are powered by AC current, why do we not see them flicker? Assuming they obey Ohm's law, the current through them is in phase with voltage, and so it must be 0 twice every period. My guess is that 60 Hz or 50 Hz used in most countries is simply so fast that our eyes don't register the flicker?
Second, this question concerns complex impedance and inductors/ resistors in circuits. Let's say we have a variable inductor in series with a resistor. Supposedly this is an example of a light-dimmer, because if we increase the inductance, then there is a larger voltage drop across it because its reactance is jωL. What I don't understand is that since the voltage is AC, and the voltage across an inductor is L*dI/dt, wouldn't there be points in the cycle that the voltage across the inductor drops to 0, and then the voltage across the light bulb should increase a whole lot! So at least momentarily, why don't light bulbs change brightness oscillating between lighter and dimmer?
I guess that question also implies the question as to how impedance can be jωL (a constant) even though there are different voltage drops at different times across the inductor.
Thanks!
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> New analysis yields improvements in a classic 3D imaging technique
>> Research effort deep underground could sort out cosmic-scale mysteries
Nov7-12, 11:08 PM   #2
Recognitions:
Homework Helper Homework Help
For 1. The filament in the bulb heats up, and it takes longer than 1/60th of a second to cool down again. The light it gives off depends on it's temperature - so it does not dim right away. You can see this when you switch off a very bright light (don't look at it) the illumination takes a short while to fade away. Lights that use other methods that respond faster to changes in current show an appreciable flicker.
For 2. You get the impedence from the relationship between voltage and current, not the voltage alone.
Nov8-12, 04:47 AM   #3
It's important to realise that ωL is not equal to Vt/It, in which Vtand It are instantaneous values, but to Vrms/Irms (or to Vpeak/Ipeak).
Nov8-12, 06:37 AM   #4
AC Circuit
Simon has is. The filament has thermal mass which tends to smooth out the flicker to a significant extent. Likewise the response of the eye/brain also tends to mask flicker although some people are more sensitive than others.
The light output from an LED responds much faster to changing input so depending on how they are driven there can be more of a flicker problem with those. Perhaps worth a read..
http://www.digikey.com/us/en/techzon...d-flicker.html
Nov10-12, 03:11 AM   #5
1.A regular bulb lights up because inside the bulb, a thin wire called a filament gets very hot and glows. When the alternating current turns off for a fraction of a second, the filament does not cool off enough to stop glowing. That is why you cannot see the flicker with this kind of bulb.
Nov10-12, 03:22 AM   #6
Recognitions:
@Nullspace0: has that answered your question?
@Abhinav R: welcome to PF; good to see someone contributing.
Nov10-12, 10:03 AM   #7
Recognitions:
Gold Membership Gold Member
The frequency chosen for the mains supply was partly based upon the perception of flicker. It's right on the edge, actually, because the UK 50Hz is significantly worse than the US 60Hz.
Flourescent tubes are significantly worse than 'laggy' filament lamps. Did you know that they tend to use low voltage AC lighting in machine shops (with rotating machinery). This is because low voltage filaments (for the same wattage) have more massive filaments and their temperature varies less over the AC cycle. This reduces flicker and means there is less chance of rotating machinery appearing to be stationary due to strobing. It helps with accident prevention in noisy environments.
New Reply
Thread Tools
Similar Threads for: AC Circuit
Thread Forum Replies
Circuit Analysis of a Positive Offset Clamping Diode Circuit Engineering, Comp Sci, & Technology Homework 6
AC circuit with dependant current and voltage source and open circuit element Engineering, Comp Sci, & Technology Homework 4
Transfer Function Mid-band Gain & Open Circuit/Short Circuit Time Constant Method Engineering, Comp Sci, & Technology Homework 1
RF transmit circuit/RF receive circuit? (Hard to explain; I made a diagram.) Electrical Engineering 8
Equiv. stiffness matrix (Mech. circuit) for hydraulic flow circuit? Mechanical Engineering 0
