Proving Limits of f(x) and f'(x) Using Differentiable Functions
  • Thread starter Thread starter Artusartos
    Proof
The discussion focuses on proving the limits of a differentiable function f(x) and its derivative f'(x) under the condition that the limit of their sum approaches a finite value L as x approaches infinity. It establishes that if lim_{x \rightarrow \infty} [f(x) + f'(x)] = L, then lim_{x \rightarrow \infty} f(x) = L and lim_{x \rightarrow \infty} f'(x) = 0. The proof utilizes the transformation f(x) = \frac{f(x)e^x}{e^x} and the properties of limits, concluding that both f(x) and f'(x) converge appropriately based on the behavior of h(x) and g(x).
  • Differentiable functions and their properties
  • Understanding of limits and convergence
  • Application of L'Hôpital's Rule
  • Exponential functions and their behavior at infinity
  • Study the application of L'Hôpital's Rule in limit proofs
  • Explore the properties of differentiable functions in calculus
  • Research the behavior of exponential functions as x approaches infinity
  • Learn about convergence tests for sequences and series
Mathematics students, calculus instructors, and anyone interested in advanced limit proofs and the behavior of differentiable functions.
Artusartos
Let f be differentiable on some interval (c, infinity) and suppose that [tex]lim_{x \rightarrow \infty} [f(x) + f'(x)] = L[/tex], hwere L is finite. Prove that [tex]lim_{x \rightarrow \infty} f(x) = L[/tex] and [tex]lim_{x \rightarrow \infty} f'(x) = 0[/tex]. Hint: [tex]f(x) = \frac{f(x)e^x}{e^x}[/tex]
My answer:
For [tex]f(x) = \frac{f(x)e^x}{e^x}[/tex], Let h(x)=f(x)e^x and let g(x)=e^x. So we have [tex]f(x) = \frac{h(x)}{g(x)}[/tex] Since we know that the sum of the limits of f(x) and f'(x) is finite, we know that each limit must also be finite. Therefore, h(x) eventually be less than g(x). So for large x, h(x) =< g(x) in order for h(x)/g(x) to converge. Since h(x)=f(x)e^x and g(x)=e^x, f(x) =< 1.
This can happen in two ways. Either h(x) is [itex]ke^x[/itex] where k is a constant such that |k|=< 1...
If this is the case, then the derivative of f(x) converges to zero, while f(x) itself converges to some number L.
...or f(x) (in f(x)e^x) is a decreasing function that converges to a number that is less than or equal to 1.
In this case, both f(x) and f'(x) converge to zero.
Do you think my answer is correct?
It seems to me that this is exactly what you needed to show in the first place. Can you show this is true?
Or if you want an easier approach, that hint suggests to me that you might want to use L'Hopital.
The limit of a sum may be finite even if neither limit is finite.Take x and -x.
  • · Replies 20 ·
