Find Center of Mass for an open box Confused about steps for this problem
The problem involves finding the height of the center of mass of an open box with a square base and rectangular sides. The box has a uniform thickness and density, with specific dimensions provided for the base and height.
  • Participants discuss the application of the center of mass formula and the reasoning behind the calculations presented by another source. Questions arise regarding the interpretation of mass in relation to area and how dimensions factor into the calculations.
Participants are actively engaging with the problem, attempting to clarify the relationship between mass and area, and exploring the implications of uniform density. Some guidance has been offered regarding the use of the formula and the significance of the dimensions involved.
There is confusion regarding the interpretation of mass as it relates to the area of the box's sides, as well as the assumptions about uniform density and thickness. Participants are encouraged to consider these factors in their reasoning.
Lo.Lee.Ta.
An appliance box has a square base with sides of length L, and has rectangular sides with a height of 3L. The top of the box is missing. The box is made from cardboard of uniform thickness and density. What is the height of the center of mass of this open box, with respect to the bottom of the box?
Equation for the center of mass is: C.M.(x) = [(m1)(x1) + (m2)(x2) +...]/[m1 + m2 +..]
C.M.(y) = [(m1)(y1) + (m2)(y2) +...]/[m1 + m2 +..]
This fellow on Yahoo Answers responded to this same question with the right answer. I am just confused about his solution... This is what he/she had written:
4 x 3L^2 x 3L/2 = 18L^3
total mass of box = 4 x 3L^2 + L^2 = 13L^2
18L^3/13L^2 = 18/13L
That is the right answer: 18/13L. But I just don't see how this method worked...
So the person squared the height of the box, and then multiplied that by 4. Why did he/she do that? That does not seem to be apart of the above formula... And then he multiplied that answer by L squared... Why are things even squared in order to solve the problem?
...As you can see, I don't get it at all... :/ Please explain this to me! Please help me to understand what each thing means in the solving of this problem!
Thank you so much for helping me! You are awesome! :)
Lo.Lee.Ta. said:
1. An appliance box has a square base with sides of length L, and has rectangular sides with a height of 3L. The top of the box is missing. The box is made from cardboard of uniform thickness and density. What is the height of the center of mass of this open box, with respect to the bottom of the box?
2. Equation for the center of mass is: C.M.(x) = [(m1)(x1) + (m2)(x2) +...]/[m1 + m2 +..]
3. This fellow on Yahoo Answers responded to this same question with the right answer. I am just confused about his solution... This is what he/she had written:
Write down what would be a value of m and x for each of the five parts of the box. You have one bottom and four identical sides. Then use your formula.
You have the correct equation:
where m1, m2, etc. is the mass of one side of the box..there are 4 sides...and y is the distance fron the cm of each side to the reference axis at the bottom of the box. So assuming unit density, how would you calculate the mass of each side of the box?
Hi! Thanks for responding! :)
Okay, so I was reading your explanation and trying to see what fit the formula:
m1(y1) + m2(y2).../(m1) + (m2) +...
So since there are 4 walls of the box that compose the height of the box with a mass of m, I wrote that the mass (m1) of the height is 4m.
Then I saw for the y1, the height of the center of mass has to be half of the wall's height, so it is 3L/2.
So the equation so far is: (4m) + (3L/2)
And I compared that to the solution for the problem.
It looks like they are saying that m (the mass) equals the area for one wall of the box.
So then I found that m= (3L x L)= 3L^2
So for the denominator of the formula, it looks like m1 has to be the 3L^2 again (to represent the mass of the sides of the box) plus the mass of the base of the box (which is again the area). So that means the base of the box has a mass of L^2.
So putting the formula together, it is (3L^2 + (3L/2)) / (4(3L^2) + L^2) = 18L^3/13L^2=18/13L <-- Answer
*What confused me in this problem was the idea that the area of a side is really also the mass of the side! Still, how is this?
How is the area also the mass? I guess I get how the answer is gotten and how to do it again, but it still does not make any sense how the area is also the mass...
Could you or someone else please explain that to me? Thank you! :)
Adding a mass to a length is not likely to produce anything meaningful.
Oh, I typed it wrong... I meant times...
I'm using the formula: (m1)(y1) + (m2)(y2) +.../ (m1 + m2 +...)
I meant (4m)(3L/2) as the (m1)(y1).
And here I made another mistake:
"So putting the formula together, it is (3L^2 + (3L/2)) / (4(3L^2) + L^2) = 18L^3/13L^2=18/13L <-- Answer"
I left out the 4 and put in a + when it should have been a x.
I meant: (4 x 3L^2 x (3L/2)) / ((4 x 3L^2) + L^2) = 18/13L
This should be right now. But I'm still confused about how the area is also the mass...
Does anyone know why it is? Thanks!
No. It's 3L^2 (the area of one side of the box), not (3L)^2. And 4 sides.
Mass is not area, mass is volume times density. However, from the problem statement,
. That should help.
  • · Replies 25 ·
15K
  • · Replies 17 ·
