New Reply
Primacy of conservation laws
Share Thread Thread Tools
Nov11-12, 06:44 PM   #35
Mentor
Relative to the reference frame. That is how velocities are always defined.
Nov11-12, 06:46 PM   #36
So where in this empty infinite universe is the origin of this reference frame?
Nov11-12, 06:49 PM   #37
Mentor
Wherever you choose, that is one of the decisions you have to make when you define a reference frame.
Nov11-12, 06:53 PM   #38
...........you define a reference frame.
But I didn't, becuse there isn't one, or alternatively one can't.
If we let the velocity of the particle be v or 1010v, what difference would it make to this universe (or the particle)?
Nov11-12, 06:59 PM   #39
Mentor
Quote by Studiot View Post
Huh? What would make you think that? There are an infinite number of reference frames you can define.
It would change the momentum and any other frame variant quantities. It would not change any frame invariant quantities.
Nov11-12, 07:32 PM   #40
K^2
Recognitions:
I mentioned the word "force" precisely once in this thread, and that was before I asked a fluid mechanics related question.
What is your thesis. State it clearly. You are not arguing a point right now, you are just bickering about stuff. That is not a way to have a conversation.
In my opinion momentum in my uniparticular universe is indeterminate since the particle's velocity is indeterminate.
Classical Mechanics is non-Relativistic. There is an absolute velocity. Fact that you aren't specifying velocity just means that you don't know its velocity, because you are being intentionally shifty about posing the question.
In Classical Mechanics, a particle has a determinate position x,y,z for any given time t. I can take position between two times and obtain velocity. That's it. If you insist that velocities are relative, then you are the one who is not sticking to the constraints of Classical Mechanics.
Now, you might be tempted to bring up Galilean Relativity, but it's not true relativity in sense that it is indistinguishable from preferred system. Just because I can re-write equations doesn't mean that particles doesn't have an intrinsic absolute velocity. It is only when you start considering motion of light relative to other objects that the concept of velocity as relative quantity becomes irrefutable. But by now you've ventured into Special Relativity where force is a relative quantity as well.
Nov12-12, 02:10 PM   #41
Quote by K^2 View Post
Lagrangian and Hamiltonian Mechanics are topics in Classical Mechanics. I'm not sure what your complaint is.
You are trying to artificially limit discussion to a static case. First of all, yes, any structural mechanics problem can be solved using Lagrange Multipliers without talking about forces. Of course, what you are actually analyzing is stress, so you have no choice but to involve forces at some point, and you might as well start balancing forces from the beginning.
Dynamics problems, however, are greatly simplified by use of Lagrangian and Hamiltonian Mechanics in generalized coordinates. That's kind of why you usually learn them in a Classical Mechanics course.
But hey, if you want Lagrangian analysis of a mass supported by the floor, here it is.
Lagrangian and constraint.
[tex]L = \frac{1}{2}m\dot{y}^2 - mgy + \lambda f(y)[/tex]
How did you get mgy?
Isn't it simpler to just write down mass times acceleration, and be done with it?
Nov12-12, 04:01 PM   #42
K^2
Recognitions:
Quote by Hetware View Post
For a mechanical system, Lagrangian is equal to total kinetic energy of the system minus the total potential energy of the system. Later gives you the mgy term. There is also a term that goes with lambda. That's due to the constraint.
Mass times acceleration is easier when you have a trivial degree of freedom with a trivial constraint. The more general problem becomes, the more effort it becomes to write out the correct equations for each DoF. In contrast, you can always write down the Lagrangian with the same amount of effort, and get the equations of motion by differentiating.
New Reply
Thread Tools
Similar Threads for: Primacy of conservation laws
Thread Forum Replies
How many conservation laws ? General Physics 8
Conservation Laws Classical Physics 13
Conservation Laws Special & General Relativity 13
Conservation Laws Advanced Physics Homework 2
I need help with Conservation Laws! Introductory Physics Homework 1
