Exploring the Inertial and Rest Mass of Quarks and Gluons in Hadrons
  • Context: Graduate
  • Thread starter Thread starter snorkack
    Component Hadron Mass
The discussion revolves around the inertial and rest mass of quarks and gluons within hadrons, exploring theoretical implications, measurement techniques, and the consequences of hypothetical massive gluons. It encompasses theoretical frameworks, experimental observations, and conceptual challenges related to quantum field theory and confinement in quantum chromodynamics (QCD).
  • Some participants question how the inertial mass of quarks inside hadrons can be measured and seek clarification on the proof of gluons being massless.
  • One participant suggests using the invariant mass of W + b-jet for measuring the top quark, while noting that charm- and bottom-mesons are dominated by the heavy quark.
  • Another participant expresses concern that introducing massive gluons would lead to significant theoretical problems, prompting requests for clarification on these theoretical implications.
  • A participant discusses the necessity of massless bosons for maintaining fundamental symmetries in quantum field theory, referencing the Higgs mechanism as a solution for W and Z bosons.
  • Concerns are raised that massive gluons would disrupt confinement, with references to differences between electroweak forces and QCD.
  • One participant points out that while photons are massless, electrons are not confined in atoms, suggesting a distinction in interactions.
  • Another participant notes that photons have no self-interaction and that the electromagnetic interaction is comparatively weak.
  • Questions are posed regarding the dependence of the strong interaction force on distance, with a participant explaining the challenges of defining a classical potential for gluon-mediated interactions.
  • Discussion includes the concept of a barrier against quark-antiquark pair creation and the energy dynamics involved in gluon chain snapping.
  • A later reply challenges the classical interpretation of cutting the gluon chain, emphasizing the quantum mechanical nature of the system and the energy considerations involved.
Participants express multiple competing views regarding the implications of massive gluons, the nature of confinement, and the measurement of quark masses. The discussion remains unresolved with no consensus reached on these complex topics.
Participants highlight limitations in classical interpretations of quantum phenomena and the dependence on theoretical frameworks, such as the need for massless bosons and the challenges in defining potentials in QCD.
snorkack
Quarks are imprisoned in hadrons, and have large binding and kinetic energies at all times. Ditto about gluons.
How can inertial mass of quarks inside hadrons be measured?
Also, how is it proven that gluons are massless? What effects would happen if gluons had rest mass, as much as up to a few MeV?
For the top-quark, you can use the invariant mass of W + b-jet, as it decays before it forms hadrons.
The masses of charm- and bottom-mesons are dominated by the heavy quark, too.
For other quark masses: Compare theory predictions (based on the quark masses) with experimental results and use the comparison as indirect measurement of the masses.
I think massive gluons would give serious theoretic problems.
So can someone explain just which the theoretical results are?
Quantum field theory uses fundamental symmetries to construct interactions between particles. To have those symmetries, bosons have to be massless.
The masses of W and Z bosons (weak interaction) were a serious issue, until Higgs and some other theoreticians developed the Higgs mechanism - it breaks the symmetry and adds mass to those bosons.
If you want to add masses to gluons, too, you need something similar for the strong interaction.
Oh, and then there are experimental limits: 1 2
With massive gluons there would be no confinement! There is no confinement due to the el.-weak force which differes from QCD in i) an additional U(1), ii) SU(2) instead of SU(3) and iii) W- and Z-masses; i) is irrelevant for confinement, ii) yields a confining theory as we know from lattice calculations, iii) is the major difference and spoils confinement
Photons are massless, yet electrons are not confined in atoms.
Photons have no self-interaction, and the electromagnetic interaction is weak.
Precisely how does the force of strong interaction (gluon chain) depend on distance for large distances?
It's not possible to write down a "classical potential" for the strong interaction mediated by gluons. The expression which can be derived is viable only as a non-local operator acting on a Hilbert space. One can extract something like a "potential" between "static valence quarks" mediated by gluons which has V(x) ~ x asymptotics for large x, but this is not a fundamemtal expression.
If you like I can post the exact expression just to convince you that it's not an ordinary potential ;-)
The more interesting analysis is that of a barrier against tunnel creation of a quark-antiquark pair, cutting the gluon chain.
If a hadron contains at least two up or down quarks then the lowest barrier path to snap the gluon chain is pion creation, with 140 MeV energy.
Of course, after snapping the chain, the halves are STILL stretched... where does the energy gain driving the gluon chain snapping come from?
That is a very classical picture, and its application is limited - the system is quantum mechanical. To "cut the chain", you do not have to create a bound hadron state (pion). A quark-antiquark pair is enough, with an energy of ~2 times the quark masses (~2*5 MeV).
  • · Replies 30 ·
  • · Replies 46 ·
