Is Our Universe Actually a 4-Dimensional Field?
  • Context: Undergrad
  • Thread starter Thread starter strid
    Concept Fields
The discussion centers on the concept of a four-dimensional universe and the implications of such a dimensionality on the nature of space and volume. Participants explore theoretical frameworks, mathematical reasoning, and conceptual clarifications regarding dimensions, particularly in relation to fitting three-dimensional objects within a four-dimensional space.
  • Some participants propose that a four-dimensional object could contain infinite three-dimensional volumes, suggesting a relationship between dimensions and volume.
  • Others argue that the fourth dimension is conventionally understood as time, challenging the notion of a purely spatial fourth dimension.
  • A participant questions the validity of summing infinite volumes or areas, suggesting that it may not make physical sense.
  • Some contributions highlight the idea of visualizing higher dimensions through analogies, such as a two-dimensional being interacting with three-dimensional objects.
  • There are discussions about the implications of moving objects through dimensions and how that might relate to the concept of volume in higher dimensions.
  • Several participants express confusion over the relationship between infinite quantities and finite spaces, with varying interpretations of what it means to fit infinite objects into a finite volume.
Participants do not reach a consensus on the nature of the fourth dimension, with some insisting it is spatial while others maintain it is temporal. The discussion remains unresolved with multiple competing views on the implications of four-dimensional space.
Limitations include varying interpretations of dimensionality, the dependence on mathematical definitions, and unresolved questions regarding the physical implications of infinite volumes in finite spaces.
strid
Thougt of a thing, reading a topic about dimnesions...
if we think like this...
a point had 0 dimensions...
there are infinite many points in a line (which has 1 dimension)
there are infinite many lines in a square (which has 2 dimensions)
there are infinite many squares in a cube (which has 3 dimensions)
following this patterns, I see it reasonable to suggest:
that there are infinite many "cubes" (objects with 3 dimensions) in a 4 dimensional "object"...
so in an "field" (or what to call it) with 4 dimensions we can fit EVERYTHING that we can see.. like the sun... or maybe ven the whole univerese...
it might then be that our universe is 4 dimensional, an therefore has infinite "space" (3 dimensions)...
hope I wasnt confusing...
Mathematics news on Phys.org
wouldnt the fourth dimension be... time? :P
Don't forget the hidden ones! You can always stuck your garbage in those...
Seriously, so you mean you can put infinity volume in a finte 4d-space? That sounds quite strange, but facsinationg.
I don't really think that is what he ment. I think he is confusing infinite steps with infinite size.
time is not the 4th dimesion I'm talking about...
I'm talking about a 4th "spacial" dimension with the quality of fitting infinite much "3dimensional stuff"
danne89, understood my point i think...
maybe volume is the better word to use instead of space...
let me then put it like this:
in a "4 dimesnional thing" there is infinite volume
as there is infinite area in a cube...'
was this clearer
Yeah, since the fourth dimension is time, what you say is exactly correct. Let me describe a 4-d object that contains "infinite" 3-volume: Me walking from the kitchen to my room.
If you think of this "content" (the generalization of length, area, and volume) as being made up of 3-volumes, you would need in an infinite number of them (1 three volume for each instant in time, exactly analagous to there being one square for each coordinate in the z dimension if you construct a cube from squares).
I am going to think about how a two dimensional creature could possibly use the third dimension as time.
If you bound the volume in all four dimensions, then the volume will be finite. I can't see how summing the area of the infinite number of cubes would make any sense.
Actually, I do believe that's what he meant. And why couldn't you? Say you have a beach full of sand you want to clear out that is full with 1000x100x10m of sand. You could (theoretically) fit all of that sand in a 1x1x1x1m 4D box (or smaller even) by filling the first layer of 1x1x1 with sand, then adding another 1x1x1 layer on top of that, since the sand is only 3D (which we are only assuming :P), it has no hyperdepth, and so, does not take up more of the hypervolume of the box than the first one (which took up 0). You can keep going until the beach is cleared and still have infinite volume to fill. (Now getting the sand back out... that's a problem :P)
EDIT:
Actually, it is many people's belief, including mine, that the "time" dimension is indeed just a spatial one. Our brains (and eyes) just take in one "slice" at a time (much like a 2D creature would need to experience a 3D object).
Crosson.. time isn't the 4th dimension, as there is a finite volume in you walking to the kitchen...
ito make an easier example.. a cube with 3*3*3cm sides is placed on the table.. over a period of time it is moved 3 cm to one side... see it than as if you had one of this really old cameras where the photographing was really slow.. every area that is blurred is the volume... so the cube would, with the movemment include the area would be 54cm^3... it would be as two cubes next to each other...
But there is still a point in what you said...
if we have a point.. and move it straight.. we get a line... if we take this line and move is perpendiculat to the line we get a square... and if we move this we get a cube... so we should get some sort of 4dimensional thing if we moved a 3 dimensional thing... but the human eye can't observe it...
but we could guess of some of its qualities... whereof one is, I suggest, that it has an infinite volume...
Mmm... yea. So what you are saying is that a hypercube encloses infinite amount of 3d space, and a normal 3d cube encloses infinite 2d area, is that right?
Then I wonder, what possible use is it to consider the area of each of the infinite planes that makes up the 3d box?
moo of doom made som good points..
about that with infinite area in a cube:
say you have a square with area 1*1cm...in a cube of 1*1*1cm, you could place infinately many such square in the cube...
But what physical sense would it have to sum up all the areas of the squares?
What you are doing is simply extending the 2d space to a third dimension by adding an axis perpendicular to the two others.
it shows us that the same way, we could (COULD) have a 4dimensional "box" where we can just stock up infinite many 3dimensional objects...
the exmaple with sand was quite good...
Try stocking up infinity many planes first then, and then we can start talking about practical applications :smile:
Well, imagine if Carl was a 2D being, and he lived in a 2D universe. He has calculated that his universe will be destroyed by a 3D object on a collision course with his plane. The only way to save his universe is to move it away. Being a brilliant scientist, he has discovered a way to create a 3D box. Now in order to save his universe, he just cuts it up into sections that will fit in the box (i. e. have the same dimensions as the base of the box). He then places each section in the box (hopefully in an ordered fashion). Since they have l*w*0 volume, he can fit as many as he needs in the box. He then moves his universe-in-a-box (don't ask me how) to a new location, and unpacks it and puts it back together. Yay, his universe is saved!
:P
you might not have noted but mathematics is not neccesarily practical :)
try to show me the value of imaginary numbers then, which is a well-accepted thing... :)
I'm not saying anything about "doing" anything.. just pointing out the interesting relaionship between the dimensions that hints that a 4dimensional object has infinite volume...
Actually, imaginary numbers have infinite (:P) application to specific types of engineering and various other fields of science. (But I forgot which, exactly >.<)
Dealing with alternating (sinousoidal) currents in electrical systems for one
And the practical aspect I brought up since in the original post, there was talk about fitting universes and suns into finite hypercubes and such...
I didn't completely understand that time interpretation for a few posts back. Can you develop it a little.
This whole discusion reminds me of a joke: "How can you visulise 4th dimension objects" "First visulise nth dimenstion and then reduce to 4th" :) Perphaps a little too old...
If I understand popular string theory right, it exist many hidden dimenstions of 4+. If you can unhide those things, what would happen. Now I maybe quite OT, but it's a fascination discusion indeed.
I don't understand the original post. Are you talking about the suggestion that the universe is a sort of higher dimensional sphere? As in, if you go straight in any direction, you'll return to the same spot?
For example, if the universe was a plane, but "in actuality" is the surface of a sphere.
i am ignorant. just try to educate me, i dare you.
No... I'm pointing on the fact that there can fit infinite many n-dimensional objects in a (n+1)-dimnesional object...
As there are infinite many points in a line...infinte many lines in a square adn etc...
so is possible (probable?) that the universe is a 4+ dimensional object that can contain infinite much 3-dimensional stuff...
Not necessarily. Depends on what you mean by "fit".
That's more of a question for physicists. As I understand it, superstring theory says there are 10 spatial dimensions.
I've hard to imagine how physicst can caonclude that there 1re 10 spatial deminsions...how would they possibly be able to do that.. sounds fascinating and inrtesting...anyone tha can explain breifly?
A least one variety of string theory (and, apparently, the one most accepted) requires 11 dimensions (10 spatial and one temporal) in order to make the fundamental values come out right. The idea is that all but 3 of them are "rolled up" tight. Imagine a sheet of paper (2 dimensions) rolled up in one direction to form a cylinder of very very small radius. Looks like a one dimensional line, doesn't it?
i recall that some of the tightly rolled dimensions are those of a calabi - yau complex threefold, but this only accounts for 6 real dimensions. what is the 7th?
Here's a quote from The Elegant Universe that should answer that (from the notes at the back of the book):
The Elegant Universe by Brian Greene said:
With the discovery of M-theory and the recognition of an eleventh dimension, string theorists have begun studying ways of curling up all seven extra dimensions in a manner that puts them all on more or less equal footing. The possible choices for such seven-dimensional manifolds are known as Joyce manifolds, after Domenic Joyce of Oxford University, who is credited with finding the first techniques for their mathematical construction.
it answers it in the sense of giving it a name, but not in the sense of explaining what that name means.
(To me, a calabi yau threefold is a complex three dimensional manifold with trivial canonical line bundle, i.e. with a never vanishing alternating three - form on its tangent bundle.)
As such, it is a 3 dimensional analog of an elliptic curve. For instance, the hypersurface of complex projective 4 space defined by a general homogeneous polynomial of fifth degree is a Calabi - Yau.
Sorry, but I don't know more about Joyce manifolds than you do. You can always Google it. Or maybe someone else on here happens to be able to explain them...
Try this: http://www.maths.ox.ac.uk/~joyce/mrrev.html. Joyce wrote a book.
  • · Replies 59 ·
232K
  • · Replies 47 ·
