New Reply
Converting Linear Accelerator To Circular One
Share Thread Thread Tools
Nov10-12, 10:23 AM   #1
Hi guys ,
Suppose there is a circular accelerator has the same inner structure of a linear accelerator in terms of the rings of acceleration ...
The angular frequency of accelerated particles is : ω = qB/m = 2πf , and this is also the supplied current frequency ...
The question is , The above formula of ω works in this case ?
Sincerely , ...
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> New analysis yields improvements in a classic 3D imaging technique
>> Research effort deep underground could sort out cosmic-scale mysteries
Nov10-12, 11:13 AM   #2
Mentor
Just for future references, "accelerator" topics do not belong in High Energy/Nuclear Physics. While accelerators ARE used in those fields, the area of accelerator physics deals mainly with classical E&M, and thus, belong in the Classical Physics forum, which is where this thread will be moved to.
Zz.
Nov10-12, 11:56 AM   #3
mfb
Mentor
For slow particles, that is fine. For relativistic particles, you need an additional factor of γ: ##\omega = \frac{qB}{\gamma m}##
Current where?
Nov10-12, 07:01 PM   #4
Quote by ZapperZ View Post
Zz.
Okay , I'll be careful in the next time
Nov10-12, 07:03 PM   #5
Quote by mfb View Post
Current where?
The current that supplied to the accelerator
Nov10-12, 08:59 PM   #6
Recognitions:
Homework Helper Homework Help
Quote by Mohamed Nedal View Post
Hi guys ,
Not sure what you are imagining here:
I think of a linear accelerator like that (link) ... so the picture I get is somehow putting the rings in a circle. But this uses electric fields so...
The angular frequency of accelerated particles is : ω = qB/m = 2πf , and this is also the frequency of the supplied current ...
... I'm not sure where the B comes in to it.
Nov11-12, 08:50 AM   #7
Recognitions:
Gold Membership Gold Member
just curious, is the decrease in angular frequency due to time dilation or an increase in mass?
Nov11-12, 09:11 AM   #8
mfb
Mentor
That is extremely vague.
The connection to the electrical grid? That can be any frequency (or even DC), it does not matter as long as you know it in advance.
The electricity for dipole magnets? That depends on the energy of the particles in the ring. In storage rings, it is constant. If the energy of the particles increases, the current has to increase in most setups, too.
The electricity for kicker magnets? Varies with the beam and the setup.
The electricity for other magnets? Depends on the magnets.
The electricity for radio-frequency cavities? Those cavities need radio frequency as input, where the frequency depends on the cavity geometry.
@greswd: It comes from the modified reaction of particles to forces: ##F_T=\gamma m a_T##. The mass of particles is constant, "relativistic mass" is something you find in outdated text books only.
Nov11-12, 04:54 PM   #9
yes I mean the current ( electricity ) that I apply on the accelerator .
According to what I understand , The angular frequency of moving particles is equal to the angular frequency of the current which is applied on the accelerator , is equal to : ω = q*B/m = 2*π*f , where ( f ) is the frequency of the current , right ?
If it was right , It is for one particle , So for all particles .. should I multiply with ( N ) the total number of particles ?
Nov11-12, 05:03 PM   #10
Mentor
You do know that circular accelerators do not move electrons the way you are describing here's don't you?
Zz.
Nov12-12, 06:17 AM   #11
yes I know how cyclotron , synchrotron , betatron .. etc. works
I suppose another design for circular accelerator
Nov12-12, 06:22 AM   #12
Mentor
I don't think you do, and you're making very little sense in this thread, but OK.
Zz.
Nov12-12, 07:30 AM   #13
mfb
Mentor
As mentioned before, that is not a useful description.
In that case, you should describe it first.
I agree with ZapperZ.
New Reply
Thread Tools
Similar Threads for: Converting Linear Accelerator To Circular One
Thread Forum Replies
linear particle accelerator General Engineering 2
Linear Accelerator Introductory Physics Homework 7
Physics behind Gaussian Accelerator/ Magnetic Linear Accelerator General Physics 10
Linear Accelerator Classical Physics 3
