Are the orders of Aut(G) and Inn(G) infinite for an infinite group G?
  • Context: Graduate
  • Thread starter Thread starter STEMucator
The discussion revolves around the properties of automorphisms and inner automorphisms of infinite groups, specifically questioning whether the orders of Aut(G) and Inn(G) are infinite when the group G itself is infinite. The scope includes theoretical considerations and examples from group theory.
  • Some participants propose that if |G| is infinite, then the orders of Aut(G) and Inn(G) should also be infinite.
  • Others argue against this by providing counterexamples, such as the group of integers, Z, which is infinite but has only two automorphisms: the identity map and the negation map.
  • A participant clarifies that the inner automorphism group Inn(Z) is trivial, indicating that it contains only the identity element.
  • There is a discussion about the injectivity and surjectivity of specific mappings, with a participant correcting a previous statement regarding these properties.
Participants do not reach a consensus; there are multiple competing views regarding the orders of Aut(G) and Inn(G) for infinite groups, with some examples supporting the idea that these orders can be finite.
Limitations include the dependence on specific group structures and the examples provided, which may not generalize to all infinite groups.
STEMucator
So I've been reading a bit about automorphisms today and I was wondering about something. I'm particularly talking about groups in this case, say a group G.
So an automorphism is a bijective homomorphism ( endomorphism if you prefer ) of a group G.
We use Aut(G) to denote the set of all automorphisms of G.
There is also an inner automorphism induced by a in G. The map f := G → G such that f(x) = axa-1 for all x in G is called the inner automorphism of G induced by a.
We use Inn(G) to denote the set of all inner automorphisms of G.
My question now :
If |G| is infinite, are the orders of Aut(G) and Inn(G) also infinite? It makes sense to me that they would be.
No. It is easy to check that [itex]\mathrm{Aut}(\mathbb{Z}) \cong \mathbb{Z}/(2)[/itex] and that [itex]\mathrm{Inn}(\mathbb{Z}) = 0[/itex].
No, not always. The integers, Z, is a group under addition. |Z| is infinite, but there are only two automorphisms on Z, given by f(x)=x (identity map) and g(x)=-x, respectively.
Ahh yes, that makes sense now because every other map doesn't generate all of Z.
So f(x) = 2x wouldn't be an automorphism for example. While it is a homomorphism, it is not injective, only surjective I believe.
Short proof to make sure : So f : Z → Z is already well defined for us. So we assume f(x) = f(y) → 2x = 2y → 2(x-y) = 0. Since 2|0, clearly x = y and f is injective. Now notice that the n elements of Z get mapped to fewer elements, so f is not surjective. Easy to show it's a homomorphism.
So f(x) = x and g(x) = -x are the only things that could be in Aut(Z) since they are the only maps which turn out to be automorphisms.
As for Inn(Z) = 0. That confused me a bit.
EDIT : Wouldn't it be Inn(Z) = { 0 } ?
They mean the same thing. Both of them are shorthand for the statement that [itex]\mathrm{Inn}(\mathbb{Z})[/itex] is the trivial group.
You switched the two around. It is injective but not surjective, which is what you proved next.
Oh whoops, mistype. Thanks for noticing.
Thanks for clarifying jgens I think I understand this now.
  • · Replies 34 ·
  • · Replies 26 ·
