Questions About the Formation of Hydrochloric Acid
  • Thread starter Thread starter avinash
    Acid Formation
The discussion revolves around the formation of hydrochloric acid through the reaction of hydrogen and chlorine, specifically focusing on the energy dynamics involved in this photochemical reaction, including activation energy and energy requirements for electrolytic separation of HCl.
  • Exploratory, Conceptual clarification, Problem interpretation
  • Participants explore the exothermic energy involved in the reaction and the activation energy required, questioning whether the topic fits within physics or chemistry. There are discussions about the variability of energy values based on experimental conditions, as well as the need to consider bond energies for calculating activation energy and exothermic energy.
Some guidance has been offered regarding the use of bond energies to determine activation energy and exothermic energy. Participants are engaging with the topic, with various interpretations being explored, particularly concerning the relationship between physics and chemistry in this context.
Participants note that experimental conditions such as pressure and temperature can affect energy values, and there is mention of external resources like the CRC handbook for data reference.
avinash
Got a question about the energy dissipated during the formation of hydrochloric acid, upon the reaction of hydrogen and chlorine (photochemical reaction). Whats the exothermic energy involved and the intensity of light needed to activate this reaction, in other words the activation energy. And what would be the energy required to separate H2 and Cl2 from a solution of HCl by electrolytic process?
thnx let me know soon.
are you sure this is a physics question? I believe that this is more general chemistry.
the endothermic and exothermic energies are all derived experimentally. this means they are not always the same. There are too many factors that affect it like pressure and temperature (eg. when it's 110*C out you need to add less heat than when it's -30 degrees out). You could try the CRC handbook to get these data. :)
You simply need to find the bond energies of [itex]Cl_2, H_2[/itex]. Add these two up, I believe that it'll be the activation energy. What light energy corresponds to this energy; you should definitely know this.
To find the exothermic energy, you'll need to incorporate the bond energy of HCl. Draw the process out. You've got diatomic gases, you dissociate them, then these species reassociate.
The electrolytic aspect pertains to free energy. You can find the voltage values of each of the reactions I mentioned and work from there.
thanx a lot I am sure that will help
39K
  • · Replies 17 ·
11K
