Finding Spring Constant from a slope with a constant x?
The discussion revolves around determining the spring constant (k) from a scenario involving a spring toy being compressed and the varying heights achieved with different masses. The original poster seeks guidance on how to graph the relationship to extract the spring constant from the slope, given a constant compression distance.
  • Participants explore different variables to plot against each other, questioning how to represent the relationship between height, mass, and the spring constant. There are discussions about the implications of using constant and varying values in the equations provided.
Some participants have offered potential relationships to plot, such as height divided by the square of the compression distance against a function of mass. There is ongoing exploration of how to rearrange equations to achieve a linear relationship that would allow for the extraction of the spring constant from the slope.
Participants express confusion regarding the mathematical representation of the problem and the correct variables to use for plotting. There is an acknowledgment of the need to clarify the relationships between the variables involved in the equations.
cameronjrhea
I quickly copied this down, so it is paraphrased but I hope it still makes sense.
Some children are playing with a spring toy, compressing it off the ground and seeing how high it bounces. When they attach different masses to it, it bounces different heights. Each time they compress the spring to exactly .02 meters. What would the children would have to graph where as the slope of the line is k, the spring constant. the mass of the spring is negligible.
Basically, if you have a constant x, but a varying height and mass, how do you find the spring constant? and what would you graph to make that the slope? I am having lots of trouble with this
F=kx
1/2kx^2 = mgh
I really don't know
I tried using x over f, but that would just result in a flat line with a spring constant of 1, which I assume is incorrect. I also solved for k and got k= 2mgh/x^2, but that still results in a straight line of a slope. I'm guessing you have to square height or mass or something but I am very confused. I don't necessarily need a complete answer as much as a guideline. I'd like to figure this out myself.
I don't know why the 1,2, and 3 showed up again. Sorry. I'm new here
It does? What two variables in that equation would you be plotting as x and y?
x^2 on the x, and 2mgh on the y.
I know that I could put mass or weight on for one variable, and height for the other, but I don't think that would solve for k, right?
Would height/x on one axis and mg on the other solve leave a slope of k? I don't even know how to check if I am right.
Oh, and thanks for replying!
But x is constant, right? Only m and h vary, so you need to plot (some function of h) against (some function of m). If you want to extract k as the slope then it needs to be in the form f(h) = k*g(m). See if you can rearrange the equation that way, then plot y=f(h) against g(m).[/QUOTE]
So with the equation 1/2kx^2 = mgh, you could extract out h and get
h=kx^2/2mg
so h/x^2= k/2mg
That way you could plot h/x^2 on one axis and 2mg on the other. and k would be the slope? I think that I understand the physics part pretty well, but I'm struggling with the math.
cameronjrhea said:
h/x^2= k/2mg
Not quite. That would be of the form Y(h) = k/X(m). To get a straight line you need to plot Y(h) = k*X(m). So what should the function X(m) be?
1/ 2mg
God this is confusing me way more than it needs to
So that goes on the x axis, and h/x^2 would be on the y axus because h/x^2 would be equal to k * 1/2mg.
Is this correct?
Thanks again for the help!
cameronjrhea said:
1/ 2mg
Is this correct?
You got it.
  • · Replies 17 ·
  • · Replies 17 ·
  • · Replies 58 ·
