Summing Powers of 10: Bernoulli's Method
  • Context: Graduate
  • Thread starter Thread starter damoclark
    Bernoulli's Method
The discussion revolves around the problem of summing the 10th powers of the first 1000 natural numbers. Participants explore various methods and historical references related to this summation, including connections to Bernoulli numbers and formulas.
  • Historical
  • One participant seeks assistance in calculating the sum of 1^10 + 2^10 + ... + 1000^10, referencing Gauss's method for summing integers as a potential analogy.
  • Another participant suggests deriving a formula for the sum of n-th powers using a telescoping sum and mentions Stirling Numbers and permutations as possible tools.
  • It is noted that the sum of the first n m-th powers is a polynomial of degree (m+1) in n, with some terms already known.
  • A suggestion is made to explore the Euler-Maclaurin summation formula, which may relate to Bernoulli numbers and could provide a quick solution.
  • A historical reference is provided regarding Jacques Bernoulli, who claimed to have quickly calculated the sum of the 10th powers of the first 1000 numbers, along with an exact value.
  • Another participant discusses the polynomial nature of the sum and attempts to approximate the sum through integration, expressing challenges in calculating coefficients without a calculator.
  • There is curiosity about alternative methods, such as using infinite series that converge quickly, in relation to the Bernoulli numbers or polynomials.
Participants express various methods and historical insights, but there is no consensus on a single approach or solution to the problem. Multiple competing views and methods remain present in the discussion.
Some participants mention known terms and methods related to the sum of powers, but the discussion does not resolve the specific calculations or assumptions involved in deriving the coefficients or applying the suggested methods.
Readers interested in mathematical summation techniques, historical methods in mathematics, or the application of Bernoulli numbers and polynomials may find this discussion relevant.
damoclark
Can anyone help me with this sum
1^10 + 2^10 + 3^10 ... +998^10 + 999^10 + 1000^10 = ?
I read that when Gauss was a kid at school he solved the simplier problem of summing all the numbers in his head between 1 and 100, before the teacher and all the other kids, by the observing the fact that 100+1=101, 99+2= 101, 98 +3 =101, etc and that there are 50 such sums, which gives an answer of 50*101=5050 for the problem.
The above sum, with powers of 10, I heard that one of the Bernoulli brothers could solve within 10 minutes with just pen and paper.
Any ideas on how he did it? I've been trying to work out a fast way to do this sum, with integrals but am always getting stuck.
It shouldn't be terribly hard (cumbersome, yes) to derive a formula for the sum of n-th powers. I think the easiest way to do this might be by employing a telescoping sum. I recall a method involving Stirling Numbers and permutations...perhaps you can even Google it ?
It's known that the sum of the first n m-th powers will be a degree (m+1) polynomial in n. (In fact, a few of the terms are known)
I don't know how fast you could solve a 10x10 system of equations, though, to determine the coefficients. I know there are easier ways of deriving this, but I don't remember them.
Try a search for the "Euler-Maclaurin summation formula", it's possible it could handle that sum by hand in 15 minutes, but I haven't tried. It involves the Bernoulli numbers and functions, so perhaps it was known to (one of) them. I confess ignorance on the history of the method though.
Jacques Bernoulli, around 1690, was evidently the first person to publish on this subject and says:
"With the help of [these formulas] it took me less than half of
a quarter of an hour to find that the 10th powers of the first
1000 numbers being added together will yield the sum
91409924241424243424241924242500"
(Hey damoclark! Is that the exact sum you are looking for?)
The reference is: http://www.mathpages.com/home/kmath279.htm .
If I remember right this was discussed in Newman's World of Mathematics
It is also known that the early terms, providing it goes that far, for nth power sums from 1 to X are: [tex]\frac{X^_(n+1)}{n+1}+\frac{X^n}{2}[/tex][tex]+\frac{nX^_(n-1)}{12}[/tex], etc., and all the terms can be constructed using Bernoulli numbers,see: http://numbers.computation.free.fr/Constants/Miscellaneous/bernoulli.html
Thanks Shmoe, I'll check out the "Euler-Maclaurin summation formula".
So the Sum could be calculated with a polynomial of order 11, which would mean I would have to substitute the value of 10^3, for the polynomial variable, to calculate the answer.
I've been looking at the function [tex]y = x^{10}[/tex], and intergrating under that to get an approximation of the answer, ie [tex]\frac{x^{11}}{11}[/tex], so an over estimation of the sum would be,[tex]\frac{x^{11}}{11}[/tex], setting x=10^3, so I guess the answer has under 33 decimal digits.
The problem, now I,m having is finding a simple way to calculate the other co-efficients, without a calculator.
Thanks for the links Robert.
So if you know the Bernoulli numbers or Bernoulli polynomial in advance you can write down the formula quickly, I assume.But I wonder if there's another way to do, maybe involving a infinite series that's converges fast...
  • · Replies 37 ·
