| New Reply |
webcam better than DSLR |
Share Thread | Thread Tools |
| Nov13-12, 06:24 PM | #1 |
Hi,
Recently started with astronomy with a basic 5 inch reflector, not motorised but interesting initial explorations. Subsequently became interested in trying to take pictures of the moon, saturn and then onto Jupiter. Found through utube that you can modify cheap webcams and in combination with registax etc and a £12 HP HD 2200 webcam managed an image of Jupiter with a little band detail on it. After much debating coughed up £300 for a canon 1100 DSLR and have replaced webcam with the camera body only on t-piece with the same barlow used with webcam , I think initially assuming I would be able to get better image detail, but I think I have fallen foul of the relative CMOS sizes in the two cameras. ie although the camera is 12MP, the sensor size is 22x14 mm approx compared with the cheap webcam which is lower pixels but on a much smaller sensor maybe 3 x 2mm . Consequently even if I use a better barlow than I have at present (2x), the final image will always be better from the webcam I believe because the jupiter image is activating more pixels in the webcam than the camera. Am I correct? (I accept the DSLR is good for wide view long exposures, so not completely waste wasted £300). |
| Nov13-12, 06:43 PM | #2 |
Mentor
Welcome to PF!
If it is planets that you want to take pictures of, then the only modification you need to make to a webcam is to remove the lens and attach an eyepiece socket adapter. Webcams are superior to DSLRs for imaging planets because they easily produce video clips, directly on your computer, with potentially thousands of individual, raw images that Registax can utilize to build a single high quality image. Image scale, however, can be corrected by changing the Barlow. The thing is, the optical resolution of a planetary image captured by an amateur telescope is pretty small, so you don't need to (and it is better not to) span too many pixels. The actual image of Jupiter only needs to be about 100 pixels across. And the fewer pixels you span, the brighter the image can be. |
| Nov13-12, 06:58 PM | #3 |
You need to get exact measurements to be sure but yes, the camera with the smallest individual pixel elements will give you the best digital resolution. Webcam can be better than the DSLR because you can capture many images over a very short time and reduce noise post processing with Registax. That's a little more difficult with the DSLR.
| Nov13-12, 09:21 PM | #4 |
The are of the sensor that the image falls on doesn't really matter. The number of pixels the image falls on is far more important. I say this because small pixels are generally better than larger pixels for getting small details on bright objects such as planets. As Russ and Chemistree said above, the number of exposures you can get can have a great effect on the final image quality.
| Nov14-12, 06:32 AM | #5 |
Cheers for all replies.
I think basically the webcam pixels individual areas are approximately half the size of the DSLR, but will perservere with the DSLR, because it took three nights with the webcam to get the brightness and contrast settings set so that I could make out some detail in the video image which then subsequently developed a better stacked image. Only shot one video so far of Jupiter with the DSLR. The DSLR (canon EOS) I have can be controlled from the computer, so its video does store directly if necessary. Just have to sort out conversion from mov to avi to load into registax, or if anyone knows is there a software which will just break the mov file down into a batch of stills I can load into registax. |
| Nov14-12, 07:41 AM | #6 |
Mentor
Can the DSLR send uncompressed video? For stacking, compression has a huge impact on quality. I use a DMK camera, which is basically a specialized for astrophotography webcam and as the resolution is increased, framerate drops due to bandwidth limitations.
| Nov14-12, 08:42 AM | #7 |
Hi Russ,
Unfortunately, I don't have any control over the camera video output. Its either set to 25 or 30 fps. So far I save the video on the camera and then transfer across once back in the warm as I've not ventured out with laptop attached to the new DSLR. The camera does have a live view option which allows objets to be enlarged 10x on the camera screen so sharper focusing can be achieved and maybe better contrast setting before shooting the video which will hopefully give a better success rate. Also because I just modified a standard webcam, the webcam only has the option of 25 to30fps control(I think). Have seen that you can get specialised webcams eg (celestron nexstar) which I think allow you to set the frame rate to lower levels which I had read can improve the eventual stacked image. CRanfieldstar |
| Nov14-12, 12:14 PM | #8 |
It can't be a matter of superior performance by a cheap and nasty webcam (even the noise performance will be poor compared with a good camera sensor). It must just be the way the optics, with no modification, are presenting a more compatible image to the Webcam.
Anyone with a good telescope and DSLR has already spent loads of money. They should be able to bring themselves to get hold of the appropriate optics that will get the best out of the two. Can it be more than just a matter of looking at the real image that the telescope is producing with a lens with the appropriate focal length that will 'fill' the field of the DSLR array? A Webcam lens will be only about 4mm (?), which gives it an advantage but you can get DSLR lenses down to 14mm focal length for not a lot and 10mm for a bit more money. It wouldn't need to be top quality, I think. But, for a couple of hundred quid (possibly a bit more, on reflection but what the hell), a suitable OEM could be found for all the good camera makes. You would then have most of your 16MPx or whatever, to play with - perhaps enough to show up all the inadequacies of your objective lens - you can't win. Have I missed some 'clincher' factor that still gives the webcam an advantage? |
| Nov14-12, 02:20 PM | #9 |
If the webcam has pixels half the size of the dslr, then perhaps its getting better resolution if the optics allow? Also, are you shooting at prime focus? IE you don't have an eyepiece between the imager and the telescope.
| Nov14-12, 05:00 PM | #10 |
I was amazed to see just how cheap these Barlow lenses are on the net. That is compared with 1.4X and 2X teleconverters for camera lenses. Why is this? I should have thought that IQ was just as important in astronomy as in normal photography.
Also, on this thread, people seem to be making the same old mistake of confusing the pitch of the sensor pixels with the quality of picture obtainable from a camera. Is there a difference in the astronomy context as well? A 'sucked acid drop' in place of a lens will never give good IQ and I know there are some ghastly webcams about - claiming HD resolution. I recently looked at some not-cheap birding telescopes and was staggered at the absolute rubbish image quality you get for your money. Consequently, I decided not to bother and to stick with my binos. However, I did subsequently buy a Kenko Lenscope which I can mount on my high quality Pentax tele lens and the results are stunning, with good contrast and low CA. I can't believe that telescope users screw a different set of eyes on when they move from telescoping and photographing. What's up? CAn someone put me right, here? |
| Nov14-12, 07:22 PM | #11 |
Hi Sophie, and Drakkith,
Am shooting with a 2x barlow in but no eyepiece which I think is prime focus in both webcam and dslr case. I removed the lens from the webcam as suggested by other sources, and just use a tpiece and ring to hold the dslr body on the scope.. So if there is a way I can get the fully focused image of jupiter falling across all the whole sensor of the dslr then that would be ideal I suppose. At present the size of the image falling on the sensors must be about 1/30 of the webcam sensor and 1/500th of the dslr sensor, but as both are recording in HD which is about 950,000 pixels, the webcam image is 30000 pixels and the dslr image 1800 pixels. |
| Nov14-12, 09:51 PM | #12 |
The pixel density of a decent dslr is so much better than your typical webcam, the only explanation for getting a dramatic result must be magnification and stacking.
| Nov15-12, 02:01 AM | #13 |
I tried looking up the specs to the webcam, but couldn't find any details on the sensor size or pixel size. The DSLR has 5.2 micron size pixels, and I could believe the webcam having smaller pixels, leading to a higher resolution. Note by resolution I don't mean the NUMBER of pixels which is usually the case. I mean the image will appear larger on the webcam and MAY capture more detail. For example, an image of Jupiter, when focused through your telescope onto the focal plane, will appear a certain size. If you have a sensor with smaller pixels, which I think someone called higher pixel density, you have the capability of seeing more detail since more pixels will be under the image. It isn't guaranteed that you will get better detail, since as I explained you may be running into the limits of your optics. |
| Nov15-12, 05:45 AM | #14 |
Mentor
A DSLR can record HD video, but it is compressed. A webcam is lower resolution because it has to transmit the video in realtime and typically uncompressed. In this context, realtime transmission and lack of compression is much more important than resolution. |
| Nov15-12, 05:51 AM | #15 |
Mentor
| Nov15-12, 06:03 AM | #16 |
Mentor
| Nov15-12, 06:04 AM | #17 |
Mentor
I can't overemphasize how big of a problem too much resolution can be: I start with TEN GIGABYTES of data to get one photo of Jupiter, which takes an hour to whittle down. Why would I want fifty more gigabytes of blackness? People tend to be shocked at just how low the resolution is on astrocams. My planetary camera is .77 MP and my deep-sky camera is 1.4MP. The deep-sky is a touch on the low side, but the planetary is perfect. One thing to remember about non-dedicated astrocams is they all have filter matrices on them that make the effective resolution about 1/3 of what is advertised. I use the 1024x768 version of this camera: http://www.optcorp.com/ProductList.a...-320-1214-1285 Note how the framerate drops as the resolution increases... |
| New Reply |
| Thread Tools | |
Similar Threads for: webcam better than DSLR
| moving into the DSLR market | Photography | 18 | ||
| Shopping for a Nikon DSLR? Better buy it soon! | Photography | 0 | ||
| Need a Nikon DSLR (not an idiot, I promise) | Photography | 2 | ||
| What is a decent entry level DSLR? | Photography | 25 | ||
| Is this [webcam] good ? | Computing & Technology | 0 | ||
