Solving Algebraic Fractions with 3 Binomials
  • Thread starter Thread starter homegrown898
    Fractions
The discussion revolves around solving algebraic fractions involving three binomials. The original poster expresses difficulty in finding a common denominator for the fractions presented, which include terms like x(x) and (x-1)(x-1).
  • Exploratory, Assumption checking, Mathematical reasoning
  • The original poster attempts to understand how to find a common denominator when dealing with three binomials. Some participants suggest multiplying the fractions by specific binomials and question the need to multiply the denominators before factoring. Others clarify notation and provide hints about cancellation.
The discussion is ongoing, with participants providing hints and clarifications regarding the approach to finding a common denominator. There is a focus on the order of operations and factoring, but no consensus has been reached on the exact method to proceed.
Participants note the importance of proper notation when writing fractions and suggest alternatives for representing squared terms. There is an emphasis on not multiplying the binomials in the denominator prematurely.
homegrown898
Since I can't write if a number is squared or anything I'll show you what I'm going to do. If X is squared I will just write x(x) That is what will represent squared. And since these are fractions I will use a slash to distinguish between the numerator and denominator.
x(x) / (x-1)(x-1) MINUS (x-1) / x+1
Where I'm having trouble is finding the common denominator. I know to find the common denominator I would need to multiply x+1 to the first fraction and multiple (x-1)(x-1) to the second fraction. But I don't know what to do when you have three binomials for common denominator.
Do I use FOIL with two of the binomials and then multiply the last binomial into that polynomial that I formed with FOIL?
What's FOIL? You can just find the common denominator by, as you say, multiplying the first fraction by (x + 1) and the second by (x - 1)^2 (you can use ^n to write to the power n, btw). What do you mean you don't know what to do when there are 3 binomials in the denominator? Some things will cancel anyway.
Yes.
But, as a hint, don't multiply the binomials in the denominator until the end. You have to multiply the binomials in the numerator so you can do your subtraction, but after you factor your result, one of the binomials in the denominator will factor out.
When writing fractions, you should wrap the entire denominator in parentheses. e.g.
[tex] \frac{1}{x+1} = 1 / (x+1)[/tex]
or
[tex] \frac{1}{(x-1)(x+1)} = 1 / ((x-1) (x+1))[/tex]
x(x) is fine for squaring x. You could use the more succint notation xx too. But, as mentioned, x^2 is more common.
  • · Replies 21 ·
