De Broglie wavelength and diffraction
The discussion centers on the de Broglie wavelength of an electron in a TV picture tube accelerated by 20,000 V. The user calculated the wavelength using the formula λ = h/mv and inquired about the relativistic effects and diffraction concerns. It was established that if the velocity (v) approaches the speed of light (c), relativistic effects must be considered, and the kinetic energy formula must be adjusted accordingly. Additionally, diffraction will affect the picture quality if the neck of the tube is comparable to the wavelength, which is significantly smaller than the tube's neck of 5 cm.
  • Understanding of de Broglie wavelength calculations
  • Familiarity with relativistic physics concepts
  • Knowledge of diffraction principles
  • Basic grasp of electron behavior in electric fields
  • Research relativistic kinetic energy equations
  • Study the principles of wave-particle duality
  • Learn about diffraction patterns and their implications in optics
  • Explore the effects of electron acceleration in electric fields
Physics students, educators, and professionals interested in quantum mechanics, particularly those studying wave-particle duality and the implications of relativistic effects on electron behavior.
josephcollins
Hi ppl I have a short question concerning the de Broglie hypothesis. I worked out the de Broglie wavelength of an electron in a TV picture tube accelerated by 20,000 V, using the fact that mv^2/2 = QV and then that lambda=h/mv. Now I need to answer whether this is relativistic or not, how do I do this? and then the neck of the tube is 5cm and I'm asked whether we have to worry about diffracttion blurring the picture on the screen. The wavelength is obviously much smaller than the neck of the tube, so diffraction will occur, will this then affect the picture? Thanks for any help, Joe
To check whether or not your calculations take relativity into account, first check to see if v is close to c. If it is then the energy is not given by 1/2*mv^2.
Secondly the neck of the tube has to be of the same order as the wavelength for diffraction to occur.
  • · Replies 17 ·
  • · Replies 28 ·
  • · Replies 27 ·
