Constructing an Edge in Progressive Betting Systems for Coin Toss Events
  • Context: Graduate
  • Thread starter Thread starter scalpmaster
    Edge System
The discussion revolves around the potential for constructing an edge in progressive betting systems applied to coin toss events, specifically focusing on the probabilities associated with single tosses versus clusters of tosses. Participants explore the implications of betting strategies based on the outcomes of these tosses, examining both theoretical and practical aspects of the proposed systems.
  • Some participants question whether an edge can be constructed by betting on clusters of 6 tosses rather than individual tosses, citing a high probability of certain outcomes.
  • One participant calculated the probability of getting HH or TT in a cluster of 6 tosses as 31/32, leading to discussions about the implications of this calculation.
  • Another participant suggested that betting should only occur after specific sequences (HTHT or THTH) to potentially increase the probability of winning.
  • There are assertions that past outcomes do not influence future tosses, emphasizing the independence of each event in a fair coin toss scenario.
  • Some participants challenge the assumptions made about the betting strategies, particularly regarding the application of the martingale system and the expected value of the bets.
  • Concerns were raised about the clarity of definitions used in the discussion, particularly regarding the interpretation of probabilities for single tosses versus clusters.
Participants express differing views on the effectiveness of the proposed betting strategies and the underlying assumptions about the independence of tosses. There is no consensus on whether a positive expectation can be achieved through the discussed methods, and the conversation remains unresolved regarding the validity of the calculations and strategies presented.
Limitations include potential misunderstandings of probability definitions, the assumptions of independence in coin tosses, and the implications of using a martingale betting system under specific conditions.
scalpmaster
I came across a post here which is puzzling:
http://quant.stackexchange.com/questions/4442/coin-toss-system
2 events:
(1) prob(H or T)of a toss = 0.5.
(2) prob(HH or TT) in a cluster of 6 tosses > 0.85.
If you are betting on event(2) .i.e.A group of 6 instead of the very next toss
Can an edge be actually constructed with some kind of progressive betting system?
2 events:
What sort of edge do you mean?
Note: I got .96875 (=31/32) for (2).
Thanks for the reply.Just wondering if we place a bet for consecutive appearance of T or H only after appearance of HTHT or THTH, would there be an advantage since probability is quite high if we count every cluster of 6 tosses as an event instead of every single toss?
Then what did you get for (1)?
Is your coin endowed with some sort of memory that makes future outcomes depend on previous ones?
Note to Norwegian - for (1) I assumed it was a fair coin, so that the probability of heads = probability of tails = 1/2.
Note to scalpmaster - Norwegians comment is correct. Past events have no effect on the outcomes of future events for coin tossing.
In that case, you may want to reconsider your previous note
as you seem to have inconsistent interpretations of "H or T" and "HH or TT".
My calculation of (2): First toss anything. To avoid HH or TT, each subsequent toss must be opposite of previous toss. For 5 tosses in a row the probability is 1/32. Therefore the probability of getting HH or TT = 31/32.
Sure, but then the probability of getting H or T in (1) must be 100%.
2 events:
If you are betting on independent groups of six then results from a previous group will have no effect on the next group.
That is not what (2) meant or whether the coin has memory or not.
If you win $1 on 9.6 times and lose $3 every 0.4 times out of 10 groups/counts of 6 tosses (applying martingale if necessary only once on 6th toss), it is a positive expectation game conceptually.
However, the assumption was that you can only start betting on the 5th toss(or 4th) which becomes unclear whether the advantage still stands(which is my question).
Basically, out of 10 groups of 6 tosses, you will find at least 9 groups with a HH or TT in it.
However, this HH or TT can occur on the 2nd, 3rd, 4th or 5th toss, and conventional martingale(limited to once) only gives positive expectation from the 4th toss onwards...unless someone can devise another scheme which still gives positive expectation(maybe smaller) but with more coverage.
Hi there, would you mind informing us of your proposed betting procedure, an in particular how you arrive at your numbers?
And again, since your coin is fair, and I suppose you are given fair odds on each bet, all bets, both individually and collectively, will have zero EV. That is a fact. Any scheme suggesting otherwise does not work, and that includes your attempt above. If you maintain your claim, you are probably breaking the forum rules, and the strict forum police may strike at any moment.
Actually martingales have infinite expectation. But it only works if you have infinite money.
I believe that he simply mispoke in the statement for (1). P(H) = P(T) = 0.5 is what I assumed he meant.
  • · Replies 67 ·
17K
