Calc Work Needed to Push Car up 11.0 deg Incline
  • Thread starter Thread starter xelda
    Friction Work
The discussion revolves around calculating the minimum work required to push a car up a 11.0-degree incline, considering factors such as mass, distance, and friction. Participants are exploring the relationship between forces acting on the car, particularly the normal force and gravitational components.
  • Participants discuss the calculation of the normal force and its relationship to gravitational force, questioning why it does not equal mg. There are attempts to clarify the components of forces acting on the car, including the gravitational force's orientation relative to the incline.
The discussion is active, with various interpretations of the normal force and its calculation being explored. Some participants have offered guidance on visualizing the problem through diagrams, while others express uncertainty about the application of energy principles due to unspecified initial and final states.
There is a noted confusion regarding the correct calculation of the normal force, with participants debating the appropriate trigonometric functions to use based on the angle of the incline. The problem also lacks specific details about initial and final velocities, which affects the application of certain theorems.
xelda
Whis is the minimum work needed to push a 1068 kg car 305 m up a 11.0 degree incline if the effective coefficient of friction is 0.26?
I have a hard time understanding why the normal force does not equal mg? How do I find the normal force? Or am I looking at this problem incorrectly?
Draw a picture of the car on the incline.
Gravity acts straight down vertically, but the normal force is perpendicular (normal) to the surface. Since the incline makes an angle with the vertical, the normal force acting on the car also makes an angle with the gravitational force.
Try to find the component of the gravitational force perpendicular to the surface (or parallel to the normal).
Apply the theorem of variation of KE...It will be immediate.
Daniel.
P.S.Compute the forces correctly...Take Galileo's advice.He's really keen on inclines...:-p
What do you mean by this?
It is just a matter of net force along the direction of motion and distance also.
The minimum work done will be the work one has to do is simply compensate the work done by gravity & frition force...Sure,in this case,bacause,the initial & final states are not specified (namely the veloities being given),one cannot use the theorem...
So my advice was not lucrative for this problem,sorry.
Daniel.
I would assume the normal force is mg x sin theta, but I was told this was incorrect?
No man. If [tex]\theta[/tex] is the angle that the incline makes with the horizontal then you take [tex]cos\theta[/tex]! Draw the picture and see why.
