Blackbody Radiation: Temperature of Accreted Gas
The discussion revolves around a homework question regarding the temperature of gas accreting onto burned-out stars, specifically in relation to blackbody radiation and X-ray emissions. Participants explore various formulas and concepts related to this topic, including Wien's displacement law and the characteristics of blackbody radiation.
  • Homework-related
  • One participant seeks clarification on how to relate the energy of X-rays (around 10 keV) to temperature, expressing confusion over the relevant formulas.
  • Another participant suggests using Wien's displacement law and provides the formula for converting energy to wavelength, emphasizing the importance of unit conversions.
  • A third participant confirms a similar temperature calculation of approximately 2*107K, indicating they arrived at this result through their own calculations.
  • One participant notes the significance of understanding the peak of the blackbody spectrum and how it relates to temperature, reinforcing the utility of Wien's law.
  • Another participant proposes an alternative formula, suggesting that while it yields a similar order of magnitude as Wien's law, it may be more appropriate given the context of accretion disks not being at uniform temperatures.
  • There is a discussion about the appropriateness of using blackbody radiation models, with one participant arguing that the problem does not specify a model, implying that blackbody radiation is a reasonable choice despite potential inaccuracies.
Participants express differing views on the best approach to calculate the temperature, with some favoring Wien's law and others suggesting alternative methods. There is no consensus on a single correct formula or model to use, and the discussion remains unresolved regarding the most appropriate method for this scenario.
Participants highlight the complexity of the problem, noting that accretion disks may not behave as ideal blackbodies and that the question may only require an order of magnitude estimate. There are also mentions of potential errors in calculations and assumptions that could affect the results.
tony873004
This is actually a homework question, but its probably better suited for this forum.
Gas accreting onto burned-out stars like white dwarfs, neutron stars, and black holes can often be seen in the X-ray part of the EM spectrum, at energies of about 10 keV. What temperature does this suggest that the accreted gas is heated to?
I can't make sense of my class notes, and the textbook does not cover this well. I can't find a formula that relates wavelength to energy to give temperature. Formulas using Watts is the closest I can come, but Watts is Joules / s, and there is no time in this problem. What did I scribble down in my notes that I can't read??
Astronomy news on Phys.org
I think what you're looking for is Wien's displacement law:
[tex]\lambda_{max}T=2.898x10^{-3} m \cdot K[/tex]
You can convert the energy of the X-Rays to wavelength using
[tex]E=\frac{hc}{\lambda}[/tex]
Just be careful to watch your units. There are several conversions to be done, and the final answer should come out in Kelvin.
Thank you very much! It took me a while, but I came up with something similar (the same, just written a little different)
[tex]t=\frac{2900 \mu m K}{\lambda_{peak}}[/tex]
and I got [tex]2*10^{7}K[/tex] if I converted my units properly.
In the interest of understanding what you're doing with all those formulae, notice that the spectrum of a blackbody has a peak in the center, and that peak moves with temperature. Wien's law simply relates the temperature and the wavelength at the peak, allowing you to find one if you know the other.
- Warren
That's what I got too. You might find http://qonos.princeton.edu/nbond/unicalc/calculator.php useful. I have to do that kind of calculation a lot and Google calculator was really tedious, so I wrote my own to save time. It's mostly for astrophysics calculations at the moment.
I think you should be using this formula:<u>~2.7kT.Incidentally,it gives the same order of magnitude as Wien's law,but there's no reason why anyone would choose Wien's law in this case...
Daniel.
Well, if it were a pure blackbody, then Wein's law would be fine. In reality, accretion disks are not at a uniform temperature, even in the simplest model. I get the impression, from the wording, that the question is just looking for an order of magnitude. The true astronomer thing to do would be to divide by Boltzmann's constant and be done with it. :biggrin:
Since the problem doesn't specify the model one would have to use,i think the BB rad.is the only viable option.As for order of magnitude,indeed,incorrect formulas may provide good answers...
...Since the errors are very large.
Daniel.
  • · Replies 29 ·
  • · Replies 49 ·
  • · Replies 21 ·
