Is there a connection between energy derivation and Newton's Law of Motion?
  • Context: Graduate
  • Thread starter Thread starter PhiPhenomenon
    Derivation
The discussion revolves around the relationship between energy derivation and Newton's Law of Motion, specifically exploring the derivation of energy formulas from classical mechanics to relativistic contexts. Participants examine various mathematical approaches and their implications, including the legality of certain operations and the consistency of variable definitions.
  • One participant attempts to derive energy from Newton's Law of motion, leading to different expressions for energy, including E = γmc² and E = 0.5mv².
  • Another participant argues that the integral ∫ v dp is incorrect because v is not constant and must be expressed in terms of momentum.
  • There are inconsistencies noted in variable definitions, particularly regarding rest mass and relativistic mass.
  • A participant expresses confusion over the legality of certain mathematical operations and the implications of their results.
  • Further exploration leads to a proposed formula for kinetic energy, but its significance is questioned.
  • One participant claims to have derived a recognizable expression from their calculations, but others challenge the meaningfulness of the result.
Participants do not reach consensus on the validity of the mathematical operations or the significance of the derived formulas. Disagreement exists regarding the interpretation of variables and the legality of certain derivations.
There are limitations in the clarity of variable definitions and the assumptions underlying the mathematical operations. The discussion highlights unresolved questions about the relationships between classical and relativistic energy formulations.
PhiPhenomenon
Hey guys,
I was trying to reverse engineer Einstein's formula for energy, E=γmc^2 by re-engineering Newton's Law of motion, F=ma. I was talking with my physics prof about deriving energy from this because I got two different answers but it gets weird because the incorrectly derived formula works.
F = ma = dp/dt -> F dx = mv dv -> E = ∫ F dx = ∫ mv dv = .5mv^2 + C
Then I did this
F = dp/dt = v dp (dx/dx) -> F dx = v dp -> E = ∫ v dp = vp + C
My prof told me that my last integral, ∫ v dp, is an illegal operation and that v must be converted into p/m which makes sense because it then follows that E = .5mv^2 = p^2/2m.
I did some fiddling around though because I was curious and I was able to derive E = γmc^2 and the formula always works. What I derived from the above was:
E = vp + C = vp + mc^2/γ, p=γmv
I'm just curious if anyone can point out why it works.
Also, I know that energy for a photon is equal to |p|c. When m=0 then v=c and I find it interesting that the rest mass, m/γ, is introduced above given energy equivalence. So, bad math or is there something to this?
Your professor is correct in that "∫ v dp = vp + C " is incorrect because v is not a constant... it is a function of p... namely (p/m) as you were told.
There are some unclear/inconsistent variable uses here:
" F dx = v dp -> E = ∫ v dp "
implies that E is the [relativistic] kinetic energy (via the work-energy theorem)
" E = γmc^2 "
implies that E is the relativistic energy and m is the rest-mass
but then you say
"find it interesting that the rest mass, m/γ,"
then m in this sentence must be the so-called "relativistic mass"
Now, when you say "E = vp + C = vp + mc^2/γ, p=γmv"
then, making the substitution for p=γmv [where m must be the rest mass],
one gets
E = vp + C = v(γmv) + mc^2/γ = m (γv^2+ c^2/γ)
where the m is factored out to unravel the expression... which is not recognizable as anything meaningful.
So, I think you have to go back and fiddle around some more... but be consistent in the meaning of your variables and don't do any illegal mathematical operations.
Thanks for the reply.
I still can't figure out why it works. At first thought that since dv = 0 the first integral is legal but that makes F = 0... So I still have no idea.
I also messed up in my original response, M/γ is actually the rest mass divided by gamma, not the formulation for rest mass.
I went a little further with it and also found a formula for kinetic energy using this:
Ek = PV(γ + 1) + Mc^2 (γ^-1 - γ^2) = γmc^2 - mc^2, P=γmc^2
Again, the math works but is it significant to anything or just a silly way of saying (gamma)mc^2 - mc^2?
one gets
After reading that over that is exactly what I got but by my calculations:
E = vp + C = v(γmv) + mc^2/γ = m (γv^2+ c^2/γ) = γmc^2 when I tried plugging in a few values assuming a=0.
E.g.:
Particle with a mass of 1000 MeV/c^2 is traveling at 0.6c -> γ = 1.25
E = 1.25 * 1000 MeV/c^2 * c^2 = 1250 MeV
Alternatively:
E = 1000 MeV/c^2 (1.25 * (.6c)^2 + c^2 / (1.25)) = 1000 MeV/c^2 (.45 c^2 + 0.8 c^2) = 1000 MeV/c^2 (1.25 c^2) = 450 MeV + 800 MeV = 1250 MeV
Just figured it out, I inadvertently made an expansion.
(γc^2) = γv^2 + c^2/γ
E = m(γc^2) = m(γv^2 + c^2/γ) = PV + mc^2/γ
  • · Replies 53 ·
  • · Replies 36 ·
  • · Replies 25 ·
  • · Replies 23 ·
  • · Replies 19 ·
