Is it possible to split water with sound wave?
The discussion centers around the possibility of splitting water using ultrasonic sound waves, exploring the underlying physics, potential methods, and implications for energy production. Participants share various theories, research references, and personal insights related to acoustic cavitation and its effects on water decomposition.
  • Experimental/applied
  • One participant inquires about using ultrasonic sound waves to split water, specifically referencing a frequency of 42,000 hertz.
  • Another participant explains cavitation, noting that it involves the formation of vapor bubbles in a liquid when pressure drops below vapor pressure, which can lead to the breakdown of water molecules.
  • It is mentioned that there is no specific frequency that causes cavitation; a range of frequencies can induce this phenomenon.
  • Some participants discuss the extreme temperatures generated by collapsing cavitation bubbles, which can exceed 5,000 Kelvin, and question whether this would affect the usability of produced hydrogen and oxygen.
  • References to various academic papers and articles are provided, discussing methods of water splitting, including sonochemistry and piezoelectric effects.
  • Concerns are raised about misconceptions regarding the combustibility of water, with some participants clarifying that water in liquid form is not combustible, while hydrogen gas is.
  • One participant mentions research on using ultrasonic cavitation to enhance the efficiency of electrolysis.
Participants express a range of views on the feasibility and methods of splitting water using sound waves, with no consensus reached on the effectiveness or practicality of the proposed approaches. Some participants challenge earlier claims and clarify misunderstandings, indicating ongoing debate.
There are limitations in the discussion regarding the assumptions made about the conditions necessary for cavitation and water splitting, as well as the definitions of terms used. The mathematical and physical principles involved are not fully resolved, and the scope of the discussion is primarily focused on theoretical and experimental aspects.
This discussion may be of interest to individuals researching alternative energy production methods, particularly those exploring innovative techniques for water decomposition and the role of acoustic energy in chemical processes.
kevin_tee
I have been researching about splitting water including electrolysis, but I came across about using ultrasonic sound wave to split water, I search around and it said that water will decompose at 42000 hertz, is this true, because I am going to do it for my project. May anyone please give me a link and theory behind it because I couldn't find it. Thank you.
Cavitation in physics is the formation of vapor bubbles of a liquid in a region where the pressure of the liquid falls below its vapor pressure. The extreme pressure reduction literally “rips” the water molecules apart and creates a bubble. This bubble contains gas that had been dissolved in the liquid. Cavitation bubbles can easily be seen near the tips of a rapidly spinning propeller under water. For a good description of hydrodynamic cavitation, see: http://en.wikipedia.org/wiki/Cavitation
Cavitation in liquids may also be caused when the low pressure portion of a powerful acoustic (sound) wave "rips" the water molecules apart and causes bubbles to form. There is no specific frequency that causes cavitation; a wide range from very low frequencies through ultrasonic frequencies all will cause cavitation in water. When a cavitation bubble collapses it compresses the gas and vapor inside it to an extremely high temperature. This can be used to cause chemical reactions not possible without acoustic cavitation. Under some specific conditions the process will emit visible light called “sonoluminescence”.
An excellent technical paper authored by some of the original pioneers in the field is this:
“Acoustic cavitation and its chemical consequences”
By Kenneth S. Suslick, et al.
http://www.scs.illinois.edu/suslick/documents/philtrans99335.pdf
See these images for acoustic cavitation:
http://www.google.com/search?q=acou...QWiloCgAg&sqi=2&ved=0CD0QsAQ&biw=1333&bih=648
Suggested search terms you may use in Google searches to learn more:
physics of acoustic cavitation in liquids
acoustic cavitation ultrasound
sonochemistry
sonoluminescence
Just as a side note, in high power sonar systems there is always the possibility of trying to transmit so much acoustic power that cavitation occurs at the face of the output transmitter (projector). This bubble field will damage the projector quickly and must be avoided. Worse yet, the bubble field drastically changes the acoustic impedance of that water and so the output sound field is attenuated. This is highly undesirable as well. As a result, sonar engineers always avoid allowing cavitation to occur.
Cheers,
Bobbywhy
thank you so much
Thank you, NascentOxygen, for addressing the kevin tee's question.
My lesson learned: pay closer attention to what the OP is asking.
Cheers,
Bobbywhy
Can hydrogen and oxygen be harvest and used? I found out that that the temperature of cavitation is more than 5000 kelvin, so will hydrogen and oxygen be combust before it can be used?
kevin tee, OOPS! Excuse me, please. I mistakenly posted all that information about cavitation without understanding your question. While it is true that acoustic cavitation bubbles, when collapsing, can generate temperatures above 5,000 degrees Kelvin, this process alone does not “split” water into Hydrogen and Oxygen.
May I suggest you begin by reading and studying this Wikipedia article?
http://en.wikipedia.org/wiki/Water_splitting
Here you will discover many various ways to split water. Please use the references at the bottom.
Here find an article about using ultrasound to generate free radicals from sonolysis of water: http://www.ncbi.nlm.nih.gov/pmc/articles/PMC3171683/
Here is an article called “Direct Water Splitting Through Vibrating Piezoelectric
Microfibers in Water”.
"ABSTRACT We propose a mechanism, a piezoelectrochemical effect for the
direct conversion of mechanical energy to chemical energy. This phenomenon is
further applied for generating hydrogen and oxygen via direct water decomposition
by means of as-synthesized piezoelectric ZnO microfibers and BaTiO3 microdendrites."
http://www.geology.wisc.edu/.../Hong_et_al_2010_J_Phys_Chem_Lett.pdf
Here is a paper called “Sonophotocatalytic decomposition of water using TiO2 photocatalyst”. “In the present work, simultaneous irradiation of ultrasound and light in order to decompose water to hydrogen and oxygen continuously has been attempted. This attempt, if proved successful, will be a typical example for a hybrid effect.”
http://www.ncbi.nlm.nih.gov/pubmed/11105323
kevin tee, I encourage you to continue searching for new, energy efficient, and innovative ways to decompose water. Your research, if successful, has the potential to revolutionize our entire production of energy.
Cheers and good luck,
Bobbywhy
Either way you can't run a car on pure water :-)
I am new here and i find it interesting and curious at the same time.. myself I am a technician and innovator as well over the years of looking into HHO i haven't yet seen one claim of water in liquid form as combustible , however in the gas form it is certainly, there are numbers of vehicles that run on natural gas, propane even hydrogen.
james1967, Welcome to Physics Forums!
Do not be misled by post #8 by CWatters! This thread was originated by kevin_tee asking about how to "split" water using acoustic energy. He never said why he wanted to do that, but clearly having the Hydrogen gas and the Oxygen gas could be useful for generating some energy.
Yes sorry for my earlier post. I can't edit it now. I'd just read one too many "water for fuel" crack pot ideas that day.
yes i understand, and i am almost confident the ..water for fuel.. they meant is the gas based fuel not the liquid form.
  • · Replies 236 ·
18K
  • · Replies 49 ·
  • · Replies 0 ·
