Calculate pH of CH3COOH & NaOH Solution
  • Thread starter Thread starter Rron
    Ph
The discussion revolves around calculating the pH of a solution formed by mixing acetic acid (CH3COOH) and sodium hydroxide (NaOH). The context includes theoretical aspects of acid-base reactions and buffer solutions, with participants exploring different methods to approach the problem.
  • Homework-related
  • One participant expresses uncertainty about how to begin the calculation for the pH of the mixed solution.
  • Another participant suggests that the strong base (NaOH) completely converts acetic acid to acetate and recommends using the expression that defines the acid dissociation constant (Ka).
  • A hint is provided regarding the concept of buffers, implying that the solution may behave as a buffer due to the presence of both the weak acid and its conjugate base.
  • It is proposed that two ICE (Initial, Change, Equilibrium) tables should be set up to outline the concentrations of the weak acid and conjugate base after the reaction with hydroxide ions.
  • One participant argues that a single ICE table may not be necessary and suggests using the Henderson-Hasselbalch equation as a straightforward method for calculating pH.
  • Another participant agrees that the Henderson-Hasselbalch equation is preferred but also emphasizes the importance of understanding concentration ratios for intuition.
Participants present multiple approaches to the problem, with no consensus on a single method. Some advocate for the use of ICE tables, while others prefer the Henderson-Hasselbalch equation, indicating a lack of agreement on the best approach.
There are varying assumptions regarding the completeness of the reaction and the necessity of using ICE tables versus the Henderson-Hasselbalch equation. The discussion does not resolve these assumptions.
Rron
A solution is prepared by mixing 200 mL of 0.2 M CH3COOH with 100 mL of 0.1 M of NaOH solution.Calculate the pH of the solution.(Ka=1.8x10-5)
I really don't know how to start this, so please help me.Its going to be a similar one on my exam tomorrow.
Thanks.
Chemistry news on Phys.org
Assume the strong base completely converts the acetic acid to acetate. From there look at the expression which defines Ka for this acid. That's a start.
If you can't see it from that information, try looking over this information.
Hint: have you heard about buffers?
This is a buffer question. You will need to set up two ICE tables. The first one outlines the remaining concentration of weak acid and conjugate base after the reaction with OH-. The second should use those concentrations to determine the final pH. If you have a book, there should be an example.
Actually no need even for a single ICE table, this is almost a simple plug and chug application of the Henderson-Hasselbalch equation. You just need to start calculating concentrations of the reaction products, assuming reaction went to completion.
Correct, the Henderson-Hasselbalch equation is the preferred method. If this student does not know where to start, however, I figured writing out the concentration ratios would help in gaining some intuition.
