| New Reply |
Can a device use more wattage than it's rated for? |
Share Thread |
| Nov20-12, 04:51 AM | #18 |
Can a device use more wattage than it's rated for?Normally the value specified on the power rating label is higher than actual consumption. In some cases the value is based on the fuse rating. eg It might be designed to consume 0.75A @ 230V = 172W but it might be fitted with a 1A fuse so the rating label might say 230W (eg 1A * 230V = 230W). Something like a 50W light bulb may draw 50W when hot but it may draw more than that for a very brief period when switched on. That's because the resistance of the filament is temperature dependant, it's resistance is lower when cold. In some/most countries regulations allow an electrician to apply a diversity rating. For example it's not unusual for an electrician to assume that a cook is unlikely to use all the rings on their electric hob/range/cooker at the same time. This may allow a big 6 ring hob to be installed on an existing circuit/wire that is apparently too small. Normally for safety reasons this circuit will be protected by an appropriate sized breaker. eg the breaker will be choosen to protect the wire feeding the hob not the rating of the hob itself. If the cook turns all the rings on at once the breaker pops. The alternative would be to rewire with a fatter wire if the supply to the house can take the increased load. |
| Nov20-12, 05:38 AM | #19 |
| Nov20-12, 06:02 AM | #20 |
Since there is so much interest in the vacuum cleaner I have rerun the tests.
Every (mains) electrical device (sold) in the UK must bear a rating plate by law. This must state the voltage, number of phases if more than one and either the wattage or the current. My vac states Input 230V 1100W max 850 Watts input IEC 950 Watts total IEC input with electrical nozzle. (Anyone know what an electrical nozzle is please?) Results: The inlet tube was blocked by placing my hand over the end. The pitch of the motor definitely increases on blocking, demonstating a speed rise. XXXXXXXXX Offload Normal Blocked Volts..........241.......241.....241.6 Current..........0.........4.16......2.68 Power............0........940........617 Frequency...49.9........49.9.......49.9 Powerfactor..1.0........0.93........0.95 VA................0.........988.......680 |
| Nov20-12, 06:27 AM | #21 |
This thread has gotten really interesting. :)
| Nov20-12, 07:25 AM | #22 |
Recognitions:
I'm kind of more interested in why input power quoted here is significantly lower than what you are getting. The power factor is also a bit low. Have you checked the cap on that motor? |
| Nov20-12, 08:24 AM | #23 |
Well you note the rating was for 850 watts at 230 volts and my mains voltage at the time was 241 volts.
So the expected power draw at 241 volts will be (241/230)2 * 850 = 933 watts. Since I could only read one parameter at a time and there was some degree of fluctuation I think that is pretty close, certainly close enough to the measured value of 940 watts. 940 watts is consistent with the measured voltage, current, VA and power factor. It should be noted that 230 (-10, +15) volts is now the nominal standard voltage in the EU. |
| Nov20-12, 09:25 AM | #24 |
Recognitions:
Am I reading this correctly? You got the power factor independent from power measurement? I suppose, you could measure phases independently and get your power factor that way, but that sounds like unnecessary extra work.
| Nov20-12, 10:03 AM | #25 |
No the instrument I used has one readout and you press buttons to display the required parameter for which it then provides continuous readout.
I have more accurate laboratory grade equipment but I didn't think it worth the setup in this case. The figures I got matched to better than 10 in 1000 or 1 in 100 or 1% which is pretty good for electrician grade measurement. The meter is the one at the extreme left in the picture in post#5 of this thread http://physicsforums.com/showthread....t=meter&page=2 |
| Nov20-12, 02:19 PM | #26 |
| Nov20-12, 03:27 PM | #27 |
Recognitions:
That brings me back to whether it's a bit low. Since you only have a 2% difference between clear flow and blocked, I would expect adjustment to within a percent to be rather simple. So .93 feels really low. Am I missing something? Or am I right to expect it to be higher? I'm thinking about it as a theorist, though. I have very little engineering knowledge of this. There might be some obvious practical reason for this that I am missing. |
| Nov20-12, 05:34 PM | #28 |
Here are some typical power factors in real life.
0.9something is well within this range. http://www.controllix.com/display.cfm/p/50/pp/4
| Nov20-12, 05:52 PM | #29 |
Recognitions:
You think there is no capacitor at all to improve power factor? Seems kind of wasteful.
| Nov20-12, 05:57 PM | #30 |
I doubt there is any correction cap on the motor but it is more than 25 years since I last disassembled a vac motor. I don't know how this motor starts either.
I can only find suppressor capacitors listed, but this would appear to be the motor http://www.espares.co.uk/part/vacuum...04t-motor.html |
| Nov20-12, 08:46 PM | #31 |
Mentor
| Nov20-12, 10:38 PM | #32 |
Recognitions:
It just seems like such an easy thing to fix for individual appliance that even the extra heating in the wiring between outlet and motor seems like a waste in comparison.
On the second point, though. The meter does charge based on RMS current, not power, doesn't it? Would it be at all practical to try and correct the power factor of the household? It'd have to be adaptive, of course, but the controller would be cheap. So long as capacitor banks required wouldn't be prohibitively expensive... I mean, we are talking 5-10% of the power bill here. That's not change. |
| Nov20-12, 10:54 PM | #33 |
Mentor
Electric meters measure real power, not current. So a slight increase in amperage for something with very little resistance doesn't change the power enough to matter. It isn't like the manufacturer of the device is paying for the power anyway -- they'd rather pocket the extra $.50 per vacuum cleaner.
And adaptive power factor correctors -- commercial ones anyway -- are still pretty absurdly expensive. |
| New Reply |
Similar discussions for: Can a device use more wattage than it's rated for?
| Rated Wattage vs actual wattage | General Physics | 7 | ||
| Fukushima Daiichi rated? | Nuclear Engineering | 49 | ||
| Space Rated Accelerometers | Aerospace Engineering | 1 | ||
| How many of you feel that birthdays are over rated? | General Discussion | 40 | ||
| Is op amp or any amplifier circuit/device a over-unity device? | Electrical Engineering | 6 | ||
