AC vs DC power loss across a resistor
The discussion centers around the differences in power loss during the transmission of electricity using alternating current (AC) versus direct current (DC). Participants explore the mathematical and conceptual aspects of power loss across resistors in both AC and DC systems, considering factors such as voltage, current, and resistance.
  • Some participants suggest that AC is preferred for power transmission due to lower losses compared to DC, while others question this assertion and emphasize that resistance is the same for both AC and DC.
  • Transmission losses are calculated as I²R, and halving the current results in a reduction of losses to one quarter, which some participants highlight as a key point.
  • There is a discussion about the ease of converting AC to high voltage for transmission and back to lower voltages, while doing the same with DC is noted to be more complicated and expensive.
  • Some participants argue that AC has advantages and disadvantages, such as the RMS value being lower than DC for the same wire diameter, which could allow for smaller diameter wires in DC transmission.
  • Concerns are raised about understanding the mathematical differences between the formulas P=IV, P=I²R, and P=V²/R, with participants seeking clarification on how these relate to transmission losses.
  • One participant points out the distinction between the voltage between the cables and the voltage drop within the cables, emphasizing the importance of higher voltage and lower current for minimizing losses.
Participants express differing views on the advantages of AC versus DC transmission, with no consensus reached on which method is superior in terms of power loss. The discussion remains unresolved regarding the mathematical implications of the power loss equations.
Participants note that the discussion involves assumptions about the phase relationship of AC current and voltage, as well as the complexities of voltage transformation in DC systems. There are also references to practical considerations in transmission that may influence the choice between AC and DC.
Crazeestuff
I was recently informed that AC is the preferred method of transmitting power because it suffers significantly less power loss going from the generating station to where ever it needs to go when compared to DC losses.
In my introductory electricity class we learned that power through a given circuit follows P=IV where P is power, I is current, and R is the resistance.
So why would the power loss be different for an AC vs DC transmission?
For AC I know there would be a low amperage and a high voltage so that you could later step the current up through a transformer so that means a low current and high voltage.
DC would just be a high voltage and low current so either way we're stuck with the same power delivery.
Even going through the substitution of P=IV=I2R the last term across a load is still P=V2/R so I just don't see how there is any difference mathematically between AC and DC power losss across a resistor.
However, conceptually it does make sense. With more current, I conceptually see why more "collisions" would occur in the wire and cause more power loss but I can't wrap my head around it mathematically.
Any help is appreciated!
It is easy to convert AC to high voltage for transmission and back to lower voltages for local distribution, doing the same thing with DC is much more complicated and expensive.
Transmission losses are calculated as I*I*R if you halve the current you get one quarter of the transmission losses. as to V*V/R or I*V remember you don't drop your total voltage over the transmission lines.
AC is better over short distances (<1000km), where the better transformators matter. If you want to transmit power over large distances, DC is better, and the losses in the transformation (they do not depend on the distance) are acceptable.
In both cases, high voltage (between the cables, not IN the cables!) and low current are important, as Jobrag showed.
The logistics part I completely get but could you elaborate on
because in my mind I still see I2* R = V2/R.
What do you mean by you don't drop the total voltage of the transmission lines.
Crazeestuff,
Resistance is the same whether AC or DC. AC might be preferred for other reasons like ease of changing voltages with a transformer, but not for resistance. Resistance is determined by the physical shape and materials of the conductors, not by what voltage or current are sent through the wires.
Those formulas are correct for both AC and DC, provided that the current and voltage are in phase in AC.
Ask the person who told you that.
That sentence does not make any sense to me.
For long distance transmission, high voltage and low current is preferred for both AC and DC to minimize IR losses.
More current causes higher IR losses in both AC and DC, so that does not make any difference.
DC power had one advantage and one disadvantage. The DC current is steady, while the AC goes to zero and reverses. That means that AC current has an RMS value that is 30% less than DC for the same wire diameter. So DC transmission can get by with smaller diameter wire, which saves a lot of money. The disadvantage is that inverters to change the voltage of DC are more expensive.
Ratch
I have no issues with the logistics of AC and DC but would you please elaborate on your last sentence? I can't see the mathematical difference in P=I*V vs P=I2*R vs P= V2/R which is my big issue.
Crazy,
OK, according to P=I*V, if you double the voltage, the transmission line needs to carry half the current to deliver the same power to a load somewhere. The transmission line resistance is constant at R, so if the current is halved, then according to (I^2)*R, the power loss in the transmission line is one quarter of what it was before.
Ratch
You have to consider two different voltages:
V between the cables, and V' as voltage drop in the cables itself.
P=V*I is the total transmitted power, and P'=V'*I is the power lost in the cables.
V'=I*R, so P'=I^2*R
The fraction which is lost in the cable is then given by (I^2*R)/(VI) = IR/V = PR/V^2 = I^2R/P
As you can see, a higher voltage between the cables and a lower current in the cables is better.
  • · Replies 50 ·
14K
  • · Replies 77 ·
  • · Replies 39 ·
9K
