Hinged beam suspended at an angle
  • Thread starter Thread starter rickbusiness
    Angle Beam
The discussion focuses on calculating the horizontal component of the force exerted by a hinge on a beam inclined at an angle of 17.8° with respect to the horizontal. The beam, weighing 35.8 kg, is supported by a cable at a right angle to the beam. The solution involves applying equilibrium conditions and using the equations of motion, specifically f=ma and t=Fr, to derive the forces acting on the beam. The final equations derived include Fxhinge = Tsin(theta) and Fyhinge = mg - Tcos(theta), leading to the overall force exerted by the hinge.
  • Understanding of static equilibrium in physics
  • Familiarity with force decomposition and vector resolution
  • Knowledge of torque and its calculation
  • Basic algebra for solving equations
  • Study the principles of static equilibrium in more complex systems
  • Learn about torque calculations in various mechanical contexts
  • Explore tension forces in cables and their applications in engineering
  • Practice similar problems involving inclined beams and hinge forces
Students studying physics, particularly those focusing on mechanics, as well as engineers and professionals involved in structural analysis and design.
rickbusiness
A 35.8 kg beam is attached to a wall with a hinge and its far end is supported by a cable. The angle between the beam and the cable is 90°. If the beam is inclined at an angle of theta=17.8° with respect to horizontal, what is the horizontal component of the force exerted by the hinge on the beam? (Use the 'to the right' as + for the horizontal direction.)
What is the magnitude of the force that the beam exerts on the hinge?
heres a picture: http://tinypic.com/r/141v7o6/6
f=ma
t=Fr
forces in the x dricection= 0
forces in the y direction= 0
net torque = 0
I think the tension can be found by L/2mgcos(theta)=LT
T=1/2mgcos(theta)
so the x component of the tension= x component of the hinge on the beam
Fx=Tsin(theta)The system is in equilibrium
Im unsure about how to approach this question because the beam is on an angle. An explanation with a worked solution would be very very much appreciated.
nevermind, figured it out. for anyone doing a similar problem here's my sol'n
Fxhinge=Tsin(theta)
Fy=0=Tcos(theta)-mg+Fyhinge
Fyhinge=mg-Tcos(theta)
Fxhinge squared + Fyhinge squared = F hinge squared
  • · Replies 42 ·
15K
10K
