Calculating Force and Acceleration Vectors
  • Thread starter Thread starter flower76
    Angles Forces
The discussion revolves around calculating the force and acceleration vectors acting on a body with a specified mass and direction of forces. The problem involves two forces, one directed due east and the other at an angle, requiring vector resolution and analysis.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss different methods for resolving the forces into components, questioning the interpretation of angles and suggesting various approaches for visualizing the problem, including drawing diagrams and using right triangles.
The conversation is active, with participants offering different perspectives on how to approach the problem. Some suggest changing the angle representation for clarity, while others advocate for maintaining the original angles and focusing on component resolution. There is no explicit consensus on the best method yet.
Participants note the importance of correctly identifying the components of the forces based on their angles, and there is an emphasis on the need for clarity in vector addition. The problem is framed within the constraints of a homework assignment, which may limit the types of solutions discussed.
flower76
I'm having trouble with this question because of the angles. Could someone point me in the right direction.
Two forces F1 and F2 act on a body of mass 28kg. F1 has a magnitude of 8N and is directed due east. The second force F2 has a magnitude of 10N and acts in a direction 50 degrees west of north. Find the magnitude and direction of the acceleration of the 28kg mass.
Maybe you'll find it easier to think of F2 as being "40 degrees north of west" instead of "50 degrees west of north". Then, resolve F2 into a West component and a North component using sin 50 and cos 50. The question is, which is which?
Draw a diagram & you should be able to figure that out.
You needn't change the angles...Simply choosing mutually perpendicular axis and ading the vectors in terms of components will do the job...
Daniel.
vectors and angles...
I think I understand how to figure out each component individually but am unsure how to put them together toget the magnitude and direction.
If you have the components,the u can make use of the right triangles and of Pythagora's theorem (for the absolute value/magnitude) and arctangent (for direction/angle)...
It's not difficult.
Daniel.
try doing it geometrically if you don't see it algebraically. Plot the vectors on a grid, head to tail, and then using the points coordinates, find the magnitude by using length of a line formula.
Regards,
Nenad
  • · Replies 18 ·
  • · Replies 25 ·
