Answer: Calculate Time for Heat Loss to Rise to Normal
The calculation of time required for a man's body temperature to rise to normal after losing heat at a rate of 300 W is determined to be approximately 0.75 hours. The process involves calculating the energy needed to raise the temperature using the specific heat capacity of the human body, which is 0.83 kcal/kg deg C. The energy required to increase the temperature by 1.5 deg C for a 65 kg individual is 81.23 kcal. By factoring in the heat produced by shivering, which is 366 kcal/hr, the net heat loss rate is calculated to be 246.05 W, leading to the conclusion that the body will take about 20 minutes to reach normal temperature.
  • Understanding of specific heat capacity (0.83 kcal/kg deg C)
  • Knowledge of energy conversion (kcal to Watts)
  • Familiarity with the concept of heat loss and production
  • Basic principles of thermodynamics
  • Learn about energy conversion formulas, specifically kcal to Watts
  • Study the principles of thermodynamics related to heat transfer
  • Explore the effects of metabolism on body temperature regulation
  • Investigate the physiological responses to cold exposure and shivering
This discussion is beneficial for students in physiology, healthcare professionals, and anyone interested in understanding human thermoregulation and heat loss mechanisms.
Kcoats
Suppose a man is losing heat at a rate of 300 W. His body temperature is 1.5 deg C below normal, and he begins to shiver. If his mass is 65 kg, how many hours will it take for his temperature to rise to normal?
Correct answer: 0.75 hrs
General feedback: First determine how much energy is required to increase the man's temperature to normal (remember you need the T change for this).
Second, determine the rate at which heat is entering the body, this will depend on the difference between the heat lost and the heat produced by shivering.
Now you can determine the time it takes for the body to gain enough heat to raise the temperature to normal.
Shivering=6.1kcal/min
6.1kcal/min (60 min)= 366kcal/hr=(.83kcal/kg deg C)(65kg)=53.95 Kcal deg C
I don't know what to do after this. Help?
You need to transform those kcal/hr in W.Can u do that...?
Daniel.
After determining the rate of heat loss and the rate of heat production from shivering, you can calculate the net rate of heat loss by subtracting the two values. In this case, it would be 300 W - 53.95 Kcal deg C = 246.05 W. This is the rate at which the man's body is losing heat.
Next, you can calculate the amount of energy needed to raise the man's temperature to normal by using the specific heat capacity of the human body (0.83 kcal/kg deg C) and the temperature difference (1.5 deg C). This would be 0.83 kcal/kg deg C x 65 kg x 1.5 deg C = 81.23 kcal.
Finally, you can use the formula Q = mcΔT to calculate the time it takes for the man's temperature to rise to normal. Q is the energy needed (81.23 kcal), m is the mass (65 kg), and ΔT is the change in temperature (1.5 deg C). This would give you a total time of 0.33 hours or approximately 20 minutes.
Therefore, it would take approximately 20 minutes for the man's temperature to rise to normal. It is important to note that this is just an estimation and may vary depending on other factors such as the man's metabolism and the surrounding temperature.
  • · Replies 21 ·
