How Far Should an Object Be Placed from a Concave Mirror to Halve Its Size?
  • Thread starter Thread starter skg94
The discussion revolves around determining the appropriate distance to place an object in front of a concave mirror to achieve a specific image size, specifically one-half the object's size. The focal length of the mirror is given as 5.0 cm, and there is a secondary question regarding the radius of curvature based on a different object placement and magnification.
  • Participants are attempting to combine the mirror equation and magnification formula to find the object distance. There are questions about the correctness of the equations being used and the relationships between object height and image height.
The discussion is ongoing, with participants exploring different interpretations of the equations involved. Some guidance has been offered regarding the correct form of the mirror equation, but there is no explicit consensus on the approach to take.
There are indications of confusion regarding the application of the mirror and magnification equations, as well as the definitions of variables involved. Participants are questioning the assumptions made in their calculations and the relationships between the variables.
skg94
1. A student wishes to place an object in front of a concave mirror in order to produce an image one-half the object's size. If the focal length of the mirror is 5.0cm, how far from the mirror should the object be placed? ANS : 15 cm.
2.An object is placed 2.0cm beyond the centre of curvatur of a concave mirror. If the magnification of this object is 0.30 what is the radius of curvature of this mirror. ANS: 1.7cm
1/f = 1/do + 1/di
m = hi/ho = -di/do
1. I believe these are questions where you have to combine two formulas, i don't know how to go about it, I am not asking for full work, if oyu decide to show full steps, I am trying to figure it out and i can't seem to do it, can someone start me off on the right track? Or if I am overthinking it put me on the right track.
1) 1/2ho/ho= f-do/do
1/2do=-f-do
2do=-2f
which would be -5, which isn't right.
1/f = 1/do + 1/di
m = hi/ho = -di/do
1/2do=-f-do
2do=-2f
What do you mean with equation (1)? ho/ho=1 and do/do=1, so eq(1) is equivalent to 1/2=f-1 which is obviously wrong.
ehild
well hi is half of ho which makes it 1/2ho, so i replaced hi with 1/2ho
and i replaced di with f-do from
f=do+di
skg94 said:
f=do+di
No, 1/f = 1/do+1/di. That's quite different.
