Using the Ratio Test to see if a series converges or diverges?
The discussion focuses on applying the Ratio Test to determine the convergence or divergence of two series: (a) \(\sum^{∞}_{n=1}\frac{3^{n}}{n^{n}}\) and (b) \(\sum^{∞}_{n=1}\frac{n!}{n^{\frac{n}{2}}}\). For series (a), the limit evaluates to 0, confirming convergence. For series (b), the limit approaches infinity, indicating divergence. Participants emphasize the importance of correctly applying the Ratio Test and clarifying the calculations involved in determining limits.
  • Understanding of the Ratio Test for series convergence
  • Familiarity with limits and sequences in calculus
  • Knowledge of factorial notation and its properties
  • Basic algebraic manipulation skills for simplifying expressions
  • Study the application of the Ratio Test in more complex series
  • Learn about other convergence tests such as the Root Test and Comparison Test
  • Explore the properties of factorials and their growth rates
  • Investigate the relationship between limits and the number e in series
Students and educators in calculus, particularly those focusing on series convergence, as well as mathematicians seeking to deepen their understanding of convergence tests.
lmstaples
Use the Ratio Test for series to determine whether each of the following series converge or diverge. Make Reasoning Clear.
(a) [itex]\sum^{∞}_{n=1}\frac{3^{n}}{n^{n}}[/itex]
(b) [itex]\sum^{∞}_{n=1}\frac{n!}{n^{\frac{n}{2}}}[/itex]
[itex]if\:lim_{n\rightarrow∞}(\frac{a_{n+1}}{a_{n}}) < 1 \Rightarrow\sum^{∞}_{n=1}\:-\:converges[/itex]
[itex]if\:lim_{n\rightarrow∞}(\frac{a_{n+1}}{a_{n}})\in[0,1)\Rightarrow \sum^{∞}_{n=1}\:-\:diverges[/itex]
[itex]0\leq \sum^{∞}_{n=1}(a_n)\leq \sum^{∞}_{n=1}(b_n)[/itex]
[itex]\:\:\:\:\:\:\:\:\:\:\:\:\:\:\:\:\:\:\:\:\:\:\:\:\:\:\:\:\:\vdots[/itex]
[itex]if\:\sum^{∞}_{n=1}(a_n)\:-\:diverges\:\Rightarrow\:\sum^{∞}_{n=1}(b_n)\:-\:diverges[/itex]
[itex]if\:\sum^{∞}_{n=1}(b_n)\:-\:converges\:\Rightarrow\:\sum^{∞}_{n=1}(a_n)\:-\:converges[/itex]
(a) I let [itex]a_{n}[/itex] = sequence of partial sums then plugged everything into ratio test formula.
I ended up with:
[itex]lim_{n\rightarrow∞}(\frac{a_{n+1}}{a_{n}})\:=\:3lim_{n\rightarrow∞}(\frac{n^{n}}{(n+1)(n+1)^{n}})[/itex]
I know that the limit equals 0 hence the series converges but not quite sure how to show that the limit cancels down to show 0 is "obvious"
Any help would be great, thanks.
(b) I let [itex]a_{n}[/itex] = sequence of partial sums then plugged everything into ratio test formula.
I ended up with:
[itex]lim_{n\rightarrow∞}(\frac{a_{n+1}}{a_{n}})\:=\:lim_{n\rightarrow∞}(\frac{n(\frac{n}{n+1})^{\frac{n}{2}}}{\sqrt{n+1}})\:+\:lim_{n\rightarrow∞}(\frac{(n)^{\frac{n}{2}}}{(n+1)^{\frac{n}{2}}\sqrt{n+1}})[/itex]
I know that:
[itex]lim_{n\rightarrow∞}(\frac{n(\frac{n}{n+1})^{\frac{n}{2}}}{\sqrt{n+1}})\:=\:∞[/itex]
And that:
[itex]lim_{n\rightarrow∞}(\frac{(n)^{\frac{n}{2}}}{(n+1)^{\frac{n}{2}}\sqrt{n+1}})\:=\:0[/itex]
Hence the overall limit = ∞ and so the series diverges; but, once again I'm not quite sure how to show that how the limits cancels down to show ∞ and 0 is "obvious"
Once again, any help would be great, thanks.
I ended up with:
[itex]\lim_{n\rightarrow∞}(\frac{a_{n+1}}{a_{n}})=3\lim_{n\rightarrow∞}(\frac{n^{n}}{(n+1)(n+1)^{n}})[/itex]
The ratio test doesn't use the sequence of partial sums. It just compares ##a_{n+1}## with ##a_n##. Your ratio of$$
\frac{3n^n}{(n+1)(n+1)^{n}}$$ is the right calculation. What happens if you overestimate the ##n^n## in the numerator with ##(n+1)^{n}##?
I ended up with:
I know that:
And that:
For (b) I get a ratio of$$
(n+1)^{\frac 1 2}\left(\frac n {n+1}\right)^{\frac n 2}$$The right half of that has something to do with the number ##e##. Is that enough of a hint?
