Why are geodesics parabolae on earth's surface?
  • Context: Graduate
  • Thread starter Thread starter bluekuma
    Geodesics Surface
The discussion centers around the nature of geodesics on the Earth's surface, particularly why they appear as parabolic trajectories. Participants explore concepts related to space-time, gravity, and the implications of local flatness in space-time.
  • One participant expresses confusion about the relationship between locally flat space-time and the expected straight trajectories of falling objects, questioning where their understanding may be flawed.
  • Another participant suggests that the path of falling objects is parabolic because it maximizes proper time, introducing a principle from general relativity.
  • A different participant clarifies that while space-time can be locally flat, gravity can still exist in that context, and emphasizes the role of tidal forces in understanding local curvature.
  • One participant notes that if their room were falling freely under gravity, objects within would follow straight lines relative to that frame, contrasting with the stationary room scenario.
  • Another participant explains that the perceived curvature of the path is due to the non-inertial reference frame of the room, which accelerates upwards, leading to curved trajectories in that coordinate system.
Participants do not reach a consensus on the explanation of why geodesics appear as parabolas. Multiple competing views and interpretations of the principles involved remain present throughout the discussion.
There are limitations in the discussion regarding the visualization of curved space-time and the assumptions made about reference frames. The relationship between local flatness and gravitational effects is also not fully resolved.
bluekuma
It's a naive question, but I'm pretty sure my professor said that space-time is locally flat (and I'm pretty sure that the volume of my room counts as "locally").
That said, I would expect falling objects to follow straight trajectories, but that's obviously not the general case.
I thought this could be because straight lines in space-time can be curved when seen in space, but it doesn't seem possible when I try to make some calculations.
Why are geodesics parabolae on the surface of earth? Where am I getting something wrong?
Thanks!
it rather comes from the principal of maximum proper time,it can be shown that path is parabola in this case because it maximizes the proper time.
This is correct. Gravity can exist in flat space-time. The local curvature is connected to tidal forces, not the gravity pull itself. And the tidal forces in your room are indeed negligible.
Exactly. But keep in mind that space-time is curved.
It is difficult to visualize the relationship for spatial parabolae, because they require 2-spatial dimensions. When you add time you have 3. Visualizing curved 3d spaces is difficult for humans. Better stick to a vertical fall, so you use only spatial dimension. Then you can visualize a distorted 2d-space time:
http://www.physics.ucla.edu/demoweb/demomanual/modern_physics/principal_of_equivalence_and_general_relativity/curved_time.gif
From: http://www.physics.ucla.edu/demoweb..._and_general_relativity/curved_spacetime.html
Note that this cone surface doesn't have intrinsic curvature. It represents a flat piece of space time, and yet produces gravity.
That's because your room is stationary relative to the Earth. Suppose instead your room was falling freely under gravity, without air resistance. Then you would find any falling objects in your room would be following straight lines, relative to your room.
If you put an accelerometer in your room you will find that your room is accelerating upwards at 1 g. So your room is a non-inertial reference frame, and so inertially moving objects will not go in a straight line. If you were to use an inertial frame which measures 0 g acceleration then you would find that a falling object would travel in a straight line at constant speed.
So, basically, it isn't the free falling object's path which is curved, it is the room's. So any coordinate system you attach to the room is curved and straight lines plotted on the curved coordinates look curved.
thanks a lot! that was a great help!
  • · Replies 76 ·
  • · Replies 30 ·
  • · Replies 35 ·
  • · Replies 31 ·
  • · Replies 27 ·
