Far field intensity distribution
The discussion centers on the far-field intensity distribution derived from the function f(x',y') = circ(ρ/D) cos(k θ x'). The Fourier transform of the circ function is established as F[circ(ρ/D)] = (π D² / 4) Jinc(kρ D / 2), where Jinc is a Bessel function. The far-field intensity is calculated using I^(z) = I₀ / (λ² z²) |F[f(x',y')]|², leading to the conclusion that the far-field intensity involves two Bessel functions, resulting in I^(z) = (I₀ / (λ² z²)) ((π D² / 2) Jinc(kx D / 2))².
  • Understanding of Fourier transforms, particularly in optics
  • Familiarity with Bessel functions, specifically Jinc
  • Knowledge of the convolution theorem in signal processing
  • Basic principles of far-field diffraction and intensity distribution
  • Study the properties and applications of Bessel functions in optics
  • Learn about the convolution theorem and its implications in Fourier analysis
  • Explore the derivation of far-field intensity distributions in various optical systems
  • Investigate the role of the circ function in signal processing and optics
Students and professionals in optics, physicists studying wave phenomena, and engineers involved in signal processing and diffraction analysis.
gboff21
Describe the far-field intensity distribution if
[itex]f(x',y') = circ(\frac{\rho}{D}) cos(\frac{k \theta x'}{2}[/itex]
where [itex]\rho = \sqrt{x^{2} + y^{2}}[/itex].
The Fourier transform of the circ function was given to us earlier:
[itex]\textbf{F} [ circ(\frac{\rho}{D}) ] = \frac{\pi D^{2}}{4} Jinc(\frac{k_{\rho} D}{2})[/itex]
where Jinc is a bessel function
I know that the Fourier transform of a product of two functions is the convolution of the two Fourier transforms. (Convolution theorem)
The far field intensity is given by [itex]\textbf{I}^{(z)} = \frac{\textbf{I}_{0}}{\lambda^{2} z^{2}} |\textbf{F}[f(x',y')]|^{2}[/itex]
Also [itex]k_{x} = \frac{k x}{z} = k \theta[/itex]
so the Fourier transform reads: [itex]\frac{\pi D^{2}}{4} Jinc(\frac{k_{\rho} D}{2}) \otimes \delta ( k_{x} - \frac{k \theta}{2} ) + \delta ( k_{x} + \frac{k \theta}{2} )[/itex]
then the [itex]\delta ( k_{x} - \frac{k \theta}{2} )[/itex] simplifies to [itex]\delta (k_{x}/2 )[/itex] and similar for the other one.
So there would be two bessel functions on the far field plane.
Is this right?
The far field intensity should then be \frac{\textbf{I}_{0}}{\lambda^{2} z^{2}} |\frac{\pi D^{2}}{4} Jinc(\frac{k_{x} D}{2}) \otimes \delta ( k_{x}/2 ) + \delta ( - k_{x}/2 )|^{2} = \frac{\textbf{I}_{0}}{\lambda^{2} z^{2}} (\frac{\pi D^{2}}{2} Jinc(\frac{k_{x} D}{2}) )^{2} Is this right?
