Power Electronics Modules and Vendors - Help Needed
The discussion revolves around finding suitable experimental modules for a Power Electronics course at the undergraduate level. Participants are sharing recommendations for vendors and specific modules that can facilitate experiments involving converters, inverters, and rectifiers.
  • Homework-related
  • Faisal is seeking reliable vendors for experimental modules that cover basic power electronics experiments, including converters, inverters, and rectifiers.
  • One participant recommends www.sindopower.com as a dedicated marketplace for power electronics suppliers, while also mentioning www.powerguru.com and Bodo's Power for additional resources.
  • Another participant suggests that the Semiteach system is suitable for standard university classes, but questions arise about the specific requirements for the experiments.
  • There is a discussion about the various types of rectifiers and inverters, emphasizing the need for clarity on voltage, frequency, and power levels to provide appropriate recommendations.
  • A scientist in the field suggests vendors like Texas Instruments, Analog Devices, and Infineon Technologies for high-quality modules, along with online marketplaces like Digi-Key and Mouser Electronics for a broader selection.
  • Concerns are raised about ensuring that the selected modules are compatible and not oversized for the intended experiments.
Participants have not reached a consensus on a single vendor or module that meets all the requirements. There are multiple suggestions and ongoing clarifications about the specific needs for the experiments.
Participants express uncertainty regarding the exact specifications needed for the experiments, which complicates the recommendations. There are also considerations about the compatibility and appropriateness of various components for the intended educational use.
Individuals involved in designing or teaching power electronics courses at the undergraduate level, as well as those seeking to procure educational equipment for similar applications.
toxic_faisal
Dear all,
I have an urgent task of finding the right experimental modules for Power Electronics Course in my university, for undergrad. level.
Could you please provide me with a list of good and reliable vendors who can provide me with modules that can enable the students to perform experiments relating to Converters (buck,boost), Inverters, Rectifiers, etc.
Your kind help will be greatly appreciated.
Thanks,
Faisal
Hello Toxic:
If you want modules - IMO the best marketplace is www.sindopower.com. In full disclosure I work for the parent company - but that is the only site I know of dedicated to PE suppliers. Another good site is www.powerguru.com - not a marketplace and not independent, but Bodo's Power is independent and they take part, and you see articles in there from competitors - etc. Lastly - it has a good global Jobs database - always interesting.
If you need top "build" a system from scratch they have the parts ( Modules, Drivers, Heatsinks, current sensors, caps and fuse blocks etc)- if you are working on the controls look up the "SEMITEACH" - it is a plexi enclosed stack for education. If you run into a situation needing 1 pc and there is a minimum buy quantity - send them and e-mail with your University details - class etc - they will help you out.
Lastly - the Semisel simulator for device selection is also the best I have seen. ( from an educational standpoint - nothing beats a Theory, planning,Simulation that you can then verify once built - it is all about the losses and heat)
Let me know the power levels and circuit details I would be happy to help with basic design and device selection.
If you need to go really cheap - you can ebay for the following Powerex, Infineon, Semikron.
Hey Windadct,
Your response was so kind and helpful. I have gone through most of the links you provided me.
If I could be clearer now, I am looking for a specific vendor, who could provided me with a module or multiple modules to carry out all the relevant experiments (involving rectifier, inverters, and different types of converters). From the above links, I could fix bits of my problem, but I am looking for one such vendor that provides modules for all of the mentioned experiments.
Note: The experiments are not very advanced, just basic power electronics course lab work.
Hope to hear from you soon.
Thanks,
Faisal Khan
Hello Again Faisal:
Unfortunately there could be thousands of experiments. If you could be more specific I can be more helpful.
Three different types of common rectifiers, and there there active rectifiers, is your source 3 phase or 1? ( If you are going to use thyristors yo will also need a trigger or firing card)
Inverters :- What voltage, frequencies ( fsw and Fout), power levels, # of phases etc.
These are all technically converters - but I am assuming you mean Buck, Boost and possible brake choppers - again many of the same apply.
Both MOSFET and IGBTs need drivers - drivers are selected based on the sige and operating conditions of the MOSFET or IGBT.
There literally thousands of possible combinations. Since these are not cheap components - I would really not want to have you buying items you do not need or are oversized, non-compatible - etc.
The Semiteach is built for standard university classes - is there a reason it is not suitable? On the smaller side look up SK 20 DGDL 065 ET - this single module is 20Anom IGBT inverter, brake and 3 phase uncontrolled rectifier, as it is IGBT switching losses account for a lot if its heat- so expect ~10A output - you still need a driver for the IGBTs - SKHI 71 - is a 7 channel driver - integrating these would require the development of a PCB.
Dear Faisal,
As a scientist in the field of power electronics, I understand the importance of finding reliable and high-quality experimental modules for your university course. I would be happy to provide you with some recommendations for vendors that offer such modules.
Firstly, I would suggest looking into companies such as Texas Instruments, Analog Devices, and Infineon Technologies. These vendors have a wide range of power electronics modules that are suitable for undergraduate level experiments in converters, inverters, and rectifiers. They also have a good reputation for providing reliable and durable products.
Additionally, I would recommend checking out online marketplaces such as Digi-Key and Mouser Electronics, which offer a variety of power electronics modules from different vendors. These marketplaces often have customer reviews and ratings that can help you in making an informed decision about the quality and reliability of the modules.
In terms of specific modules, I would suggest looking for ones that have a simple and user-friendly design, as well as clear instructions for students to follow. It would also be beneficial to choose modules that have built-in safety features and protection mechanisms to ensure the safety of your students while conducting experiments.
I hope this information helps you in finding the right vendors and modules for your Power Electronics course. Best of luck in your search and please do not hesitate to reach out if you have any further questions.
Sincerely,
  • · Replies 0 ·
