How does a cockroft walton multiplier work?
  • Context: Undergrad
  • Thread starter Thread starter Thundagere
    Work
The discussion revolves around understanding the operation of a Cockcroft-Walton multiplier, including its current flow, the role of diodes and capacitors, and the differences between various configurations. Participants seek clarification on the theoretical aspects and practical applications of the multiplier.
  • One participant requests an explanation of how the Cockcroft-Walton multiplier works, specifically regarding current flow and the differences between full-wave and other configurations.
  • Another participant suggests using search engines for initial research and encourages self-study before returning with specific questions.
  • A participant expresses confusion about how capacitors in the multiplier charge each other and questions whether an AC source is necessary for operation.
  • A later reply provides a detailed explanation of the operation of the multiplier, describing how diodes and capacitors interact during AC cycles to increase voltage.
  • One participant acknowledges the helpfulness of the provided resources and expresses intent to revisit them for better understanding.
Participants exhibit a mix of confusion and attempts to clarify the workings of the Cockcroft-Walton multiplier. There is no consensus on the understanding of the operation, with some participants providing explanations while others seek further clarification.
The discussion highlights a reliance on external resources for foundational understanding, with some participants indicating gaps in their comprehension of the theoretical principles involved.
This discussion may be useful for individuals interested in electrical engineering, circuit design, or those seeking to understand voltage multipliers and their applications.
Thundagere
Could someone help me out? I've looked at the two following diagrams:
http://upload.wikimedia.org/wikipedia/en/4/4c/Cockcroft_Walton_Voltage_multiplier.png
Full wave multiplier
I'm not understanding how it works in terms of current flow and such. COuld someone explain this? Also, what's the difference between these two setups insofar as how well they work? I understand that it has something to do with using diodes to send the current in a specific way, and then charging capacitors in each stage, but beyond that, I'm not sure.
Thanks!
Google is your friend. I got about 12,400 results in (0.24 seconds) using the search terms “cockroft walton multiplier”. I selected these two for you. No spoon-feeding here on PF. You must go to these sites and study and learn yourself. If then you have any questions or doubts, return here and post them. Good luck.
http://en.wikipedia.org/wiki/Cockcroft–Walton_generator
http://www.allaboutcircuits.com/vol_3/chpt_3/8.html
Cheers,
Bobbywhy
Been there done that :). I stared at this image for about 10 minutes before coming here.http://upload.wikimedia.org/wikipedia/en/4/4c/Cockcroft_Walton_Voltage_multiplier.png
To be more specific, here in this image. THe power source charges the top left capacitor, but how does this effect stack up to add to the voltage? There's a path from the voltage source to every capacitor, so every capacitor is charged, but do the capacitors then charge each other? Is that why the "stacking" effect works? I feel like I'm missing something as far as the overall swing of things is.
Also, does the current source have to be AC current? This diagram shows it like so, but could you use a rectifier and an AC source to convert, say, 120 volts of AC wall current to 168 volts DC, then use a Cockroft-Walton multiplier to stack the 168 volts?
Been where, done what? Staring at a schematic diagram seems an unlikely method to learn the theory of operation.
At the Wiki site mentioned above, the words "Operation of the CW multiplier, or any voltage doubler, is quite simple. Considering the simple two-stage version diagramed within, which is attached to an AC power source on the left side of the diagram. At the time when the AC input reaches its negative pole the leftmost diode is allowing current to flow from the ground into the first capacitor, filling it up. When the same AC signal reverses polarity, current flows through the second diode filling up the second capacitor with both the positive end from AC source and the first capacitor, charging the second capacitor to twice the charge held in the first. With each change in polarity of the input, the capacitors add to the upstream charge and boost the voltage level of the capacitors downstream, towards the output on the right. The output voltage, assuming perfect conditions, is twice the peak input voltage multiplied by the number of stages in the multiplier." seem to explain the workings of the CW multiplier fairly well.
Have you studied the first section in the above "all about circuits" site? It provides a simplified theory of operation.
Cheers,
Bobbywhy
I honestly didn't see that section in the link you gave me. At any rate that site seems really good for this, so I'll give it another go. Thanks!
  • · Replies 24 ·
