New Reply
Does logarithmic decrement depend on initial amplitude?
Share Thread Thread Tools
Nov24-12, 07:16 PM   #1
Lets say we have a weight attached to a spring. When releasing it under water (whole motion occours under water) at different initial amplitudes, will logarithmic decrement be the same? And will the period change?
I think it should be the same for different initial amplitudes. But [itex]\Theta=\frac{T_1}{t}\ln\frac{A_1}{A(t)}[/itex], where [itex]T_1[/itex] is period of first cycle, [itex]t[/itex] is time until amplitude is [itex]A(t)[/itex] and [itex]A_1[/itex] is initial amplitude, suggests that when initial amplitude increases, logarithmic decrement must increase as well, or the ratio [itex]\frac{T_1}{t}[/itex] must decrease.
So... which one is correct?
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> Study provides better understanding of water's freezing behavior at nanoscale
>> Soft matter offers new ways to study how ordered materials arrange themselves
>> Making quantum encryption practical
Nov24-12, 08:01 PM   #2
Math 2012
Recognitions:
Your formula for log dec is only correct when the time interval is an exact multiple of the oscillation period.
In real life, you can use the formula approxiamately for any time interval, by drawing a smooth curve through the maximum amplitude of each cycle, and using that curve for the amplitudes "A" in the formula.
Also, the log dec is only constant if the damping force is proportional to velocity. That is the "standard" equation that you study for single degree of freedom damped systems, but in real life damping forces are often NOT proportional to velocity. For example the damping force caused by viscosity of a fluid (like your water example) is approximately proportional to velocity squared, except at very low velocities.
As another example, a frictional damping force that obeys Coulomb's law of friction is constant (indepdendent of velocity). For friction damping, the motion will stop completely after a finite number of oscillations, which can't happen with the log dec is constant.
New Reply
Thread Tools
Similar Threads for: Does logarithmic decrement depend on initial amplitude?
Thread Forum Replies
Logarithmic decrement of a lightly damped oscillator Advanced Physics Homework 1
Simple problem: logarithmic decrement Advanced Physics Homework 2
logarithmic decrement Calculus & Beyond Homework 3
Torsional pendulum, logarithmic decrement Engineering, Comp Sci, & Technology Homework 1
Torsional Pendulum, Logarithmic Decrement Introductory Physics Homework 1
