New Reply
Car mass and maximal speed when cornering
Share Thread Thread Tools
Nov25-12, 05:24 AM   #1
Hello, I would really appreciate if someone helped me to figure this out.
Suppose we have got a car A and car B. They both have got the same body (aerodynamics), tires, center of mass, the only difference is that the car B is x times heavier than car A. Now suppose they are both going around the same corner without loosing traction and without going sideways.
The question is which car can go around the corner faster?
My intuition tells me that the lightest car can corner faster, because car B is heavier thus it has more inertia and when going the same speed it has got higher kinetic energy. But the heaviest car should also have more friction between tires and road resulting in better traction when cornering. Do both of these effects cancel each other out?
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> A quantum simulator for magnetic materials
>> Atomic-scale investigations solve key puzzle of LED efficiency
>> Error sought & found: State-of-the-art measurement technique optimised
Nov25-12, 05:40 AM   #2
K^2
Recognitions:
Heavier car will also have more traction to use towards cornering by the same factor x. So both cars will be able to corner at exactly the same speed, at least in the idealized case.
Realistically, less tire deformation might give a lighter car a slight advantage.
Another real world consideration is that when you load the car, increasing its weight, you usually raise the center of mass as well, increasing risk of the car tipping over in a turn. But this is all about the height of CoM in relation to wheel base, and isn't directly tied to car's weight.
Nov25-12, 05:14 PM   #3
Recognitions:
Homework Helper Homework Help
The limiting cornering speed is independent of the mass.
Nov25-12, 08:10 PM   #4
Recognitions:
Quote by Meir Achuz View Post
Yes, in the idealized situation that OP is (almost certainly) trying to ask about: centripetal force supplied by friction between tire and road, everything else the same.
But note that OP also specified the same aerodynamics. If the aerodynamics are the same, then the limiting cornering speed is not independent of the mass. If there is an aerodynamic downforce (any purpose-built racecar, many high-performance road cars) then the lower the mass, the higher the limiting cornering speed will be.
New Reply
Thread Tools
Similar Threads for: Car mass and maximal speed when cornering
Thread Forum Replies
Why do riders hang off a motorbike when cornering? Classical Physics 7
What is the best way to calculate the maximal speed of a beta particle Introductory Physics Homework 0
Normal Forces on Tyres while cornering Classical Physics 13
Optimal mass distribution for maximal gravitational field Advanced Physics Homework 0
Motorcycle cornering... General Physics 5
