Kg-meter required for 1 MWH generator
  • Context: Undergrad
  • Thread starter Thread starter pmk69
    Generator
The discussion revolves around the energy requirements for running a 1 MW generator for one hour, specifically focusing on the conversion of energy units and the implications of using kg-m/sec as a measure of power. Participants explore the relationship between torque, angular velocity, and the necessary energy to sustain generator operation.
  • One participant states that 3600 Mega Joules/hour is required to run a 1 MW generator for one hour, equating this to 102,000 kg-m/sec.
  • Another participant asserts that a properly designed 1 MW generator can deliver power as long as it has fuel, implying it can run for more than just one second.
  • There is a question about whether 102,000 kg-m/sec is sufficient to run the generator for one hour or just one second, with calculations presented for power requirements over different time frames.
  • A participant provides a formula for calculating torque based on power and angular velocity, concluding that the generator requires 6369 Nm of torque at 1500 rpm.
  • Another participant converts 102,000 kg-m/sec into watts, suggesting that it equates to approximately 999,600 W, which is less than the required 1,000,000 W for the generator.
  • Some participants express confusion over the use of kg-m/sec as a unit, questioning its validity and how it relates to power and energy.
  • One participant clarifies that to run a 1 MW generator for one hour, 367,346 kg-m of energy would be required, considering efficiency losses in practical scenarios.
  • There are discussions about the efficiency of generators and how much energy would need to be stored to account for losses.
  • Participants also engage in clarifying the conversion between different energy units, with some proposing different interpretations of the calculations involved.
Participants express differing views on the interpretation of energy units and the calculations related to running the generator. There is no consensus on the validity of using kg-m/sec as a measure of power, and the discussion remains unresolved regarding the exact energy requirements and efficiency considerations.
Some participants note potential ambiguities in the units used and the assumptions made in calculations, particularly regarding the efficiency of the generator and the nature of the energy source.
pmk69
Dear Friends,
I need some details to run 1 MW Generator. I found that 3600 Mega Joules/hour (3.6 Giga Joules/hour) required to run 1 MW Generator for 1 hour i.e 1 MWH.
3600 Mega Joules/hour = 102,000 Kg-m/sec.
I want to know that Can we run 1 MW Generator (1500 rpm) for 1 hour to supply 1 MWH using this 102,000 Kg-m/sec. Or Only able to run the 1 MW Generator for 1 sec using that 102,000 kg-m/sec?
Help highly appreciated.
thank you
pmk69
A 1 MW generator, if properly designed, will deliver 1 MW as long as it has fuel. Not just 1 second.
102,000 kg-m/sec force enough to run 1 MW Generator (1500 rpm) for 1 Hour? This is what I actually need?
OR
102,000 Kg-m/sec - required to run 1 MW Generator for 1 sec?
60 x 102,000 = 6120000 Kg-m/minute - required to run 1 MW Generator for 1 minute?
60 x 6120000 = 367,200,000 Kg-m/hour - required to run 1 MW Generator for 1 hour?
thanks
pmk69
Power (in Watts) = Torque (in Newton meters) * Angular velocity (in Rads/s)
so
Torque = Power/Angular velocity
at 1500 rpm the angular velocity in rads/s is...
= 2∏ * 1500/60
= 157 rads/s
Therefore..
Torque = 1,000,000/157 = 6369 Nm
So your generator appears to require a motor capable of producing 6369 Nm of torque at 1500 rpm.
Edit: Your generator will keep delivering 1MW for as long as your motor keeps delivering 6369 Mn at 1500 rpm.
If I have understood correctly you mean..
102,000 kg-m/sec = 102,000 x 9.8 = 999,600 Nm/sec
Now..
force (in Newtons) * velocity (in m/sec) = power (watts)
so what you are saying is that your source is 999,600W.
Since 999,600W < 1,000,000W the answer to your question appears to be no.
However even if you decide it's close enough your data still doesn't have enough info to answer the question fully. For example how is your source power delivered? Is it in the form of electrical power? linear motion? rotary motion at the right rpm?
The generator needs 1MW (6369 Nm, at 1500 rpm) where as you have 0.99MW (?Nm, at ?? rpm).
The difference between 999600 W and 1 MW is negligible and stems from rounding errors. The OP converts MW into kg m/sec (I don't know why). I think the word second is the key because it makes pmk69 think the generator would run for only a second.
On the other hand, perhaps the OP just want to ask the amount of energy needed to run the generator 1 hour, but it isn' so clear.
Hi CWatters,
Thanks for your reply. Available energy is in the form of Linear and it should be converted into Rotary Motion using Gear Box (Like Wind Mill) to give required RPM, For example 1500 RPM, to run a 1 MW Generator. So, I need to know whether the said (1,02,000 Kg-m/Sec) energy can be used to run a 1 MW Generator for 1 Hour to produce 1 MWH?
Yes Gordianus. This is where I need clarification. Can we run 1 MW Generator for 1 Hour to produce 1 MWH using this 102,000 Kg-m/s?
In my book "Kg-m/Sec" is a ambiguous unit because force isn't measured in kg but Newtons. So can you tell us how you arrived at 1,02,000 Kg-m/Sec ?
kg.m/sec looks like force (kg) x velocity (m/s) which equals power not energy. So asking how long it will run a 1MW generator is meaningless. It's like asking how long can a 100bhp car engine can deliver 100bhp?As I said above..
102,000 kg-m/sec = 102,000 x 9.8 = 999,600 Nm/sec = 0.99 MW which is less then 1MW so the short answer is no. You can't run a 1MW generator from 102,000 kg-m/sec for any length of time (but it's close if you ignore losses in the generator and gearbox).
This is the URL that I referred. You can also check that:
http://www.convert-me.com/en/convert/power/
Simply to say, How much energy (in Kg-m) I need to run 1 MW generator for 1 hour. I have to store available mechanical energy (Linear) and used that energy to run the Generator.
thanks
pmk69
Ah that's a slightly different and easier question...
First let's assume the generator and gear box are 100% efficient..
Energy (in Joules) = Power (in Watts) * Time (in seconds)
= 1MW * 3600 Seconds = 3,600 MJ
You can then convert that to other units...
3600 MJ = 3600 M N.m or
3,600,000/9.8 = 367,346 Kg-m
Could be done with 367,346 kg of water lifted 1 meter or 36,735 kg lifted 10m etc
However most generators are going to be less than 40% efficient so in practice you need to store at least 100/40 = 2.5 times that much energy and probably more like 4 times. Plus whatever the pump uses to lift the water into storage.
this is what I actually need. If I want to run 1 MW generator (for example, theoretically 100% efficient) for 1 hour is 367,346 kg-m.
For 24 Hrs = 367,346 x 24 = 8,816,304 kg-m
For 365 Days(1 Year) = 8,816,304 x 365 = 3217950960 kg-m
i.e. 3217950.96 tonnes-m or 3.21 million tonnes - m
Is this correct?
anyway great thanks to you.
pmk
how to mark the "Helpful" button?
if reply is helpful to solve the issue, we have to mark the reply as "Helpful" and Mark the thread as "Solved"? How can we do it here?
thanks
pmk69
Is this conversion correct?
OR
this one is correct?
3600 MJ = 3,600,000,000 Joules = 3,600,000,000 N-m = 36,000,000 Kg-m
regards,
pmk69
EDIT: Nevermind, it all become clear.
The units are different, they are not the same. And even if you add a factor of g, there is one digit missing.
3,600,000,000 Nm = 360,000,000 kg*m * g
(with the approximation of g=10m/s^2)
Those features are not enbled here on the PF.
20K
9K
  • · Replies 42 ·
20K
