Angular Frequency of Damped Oscillator
The angular frequency of a damped oscillator can be calculated using the formula ω0 = √(k/m), where k is the spring constant and m is the mass. In this discussion, the spring stiffness is given as 15 cm (0.15 m) and the mass is derived from a force of 19.6 N, resulting in approximately 2 kg. The damping constant is 15 kg/s, which is used in the calculation of the damping ratio ζ = c/(2√(mk)). The unit of angular frequency is confirmed to be in radians per second (rad/s).
  • Understanding of basic physics concepts related to oscillators
  • Familiarity with the formulas for angular frequency and damping ratio
  • Knowledge of unit conversions (N to kg, cm to m)
  • Basic algebra skills for manipulating equations
  • Study the derivation of angular frequency in damped harmonic oscillators
  • Learn about the implications of the damping ratio ζ in oscillatory systems
  • Explore the effects of varying spring constants on oscillation frequency
  • Investigate real-world applications of damped oscillators in engineering
Students studying physics, engineers working with mechanical systems, and anyone interested in the dynamics of oscillatory motion will benefit from this discussion.
cd6
1. What is the angular frequency of a damped oscillator whose spring stiffness is 15 cm with a 19.6 N mass and a damping constant of 15 kg/s?
2. ω0 = √(k/m) ----where k = spring constant and m=mass
ζ= c/(2√(mk)) -----where m = mass, k = spring constant, and c = damping constant
3. I first converted N to kg to get the mass. It resulted in ≈ 2 kg. The 15 cm would also be converted to .15 m. However, I don't know which formula to use. ζ is dimensionless but utilizes all three values given in the question; I need my answer in rad/s. The first equation using ω0, too, wouldn't give me those unit. I really just need a formula. This is my first post here, so I'm sorry if I'm lacking an appropriate description. I seriously just don't understand this problem. Thank you in advance!
ζ is not the angular frequency of the damped oscillator.
Read
http://en.wikipedia.org/wiki/Harmonic_oscillator#Damped_harmonic_oscillator
The unit of angular frequency is 1/s. What is the unit of √(k/m)?
ehild
