Interpretation of the integration domain symbol
The discussion revolves around the interpretation of the domain of integration symbol in mathematical notation, particularly in the context of changing variables during integration. Participants explore whether the domain of integration is invariant under coordinate transformations or if it represents the values taken by the variables involved.
  • One participant questions whether the domain of integration D is invariant, suggesting that it may represent the values taken by variables, leading to D' being different from D.
  • Another participant asserts that D and D' generally represent different sets of numbers, indicating they are different subsets of the real number line.
  • A further contribution discusses the nature of surface integrals, arguing that the symbol for the domain may imply invariance, which creates confusion.
  • One participant provides a counterexample involving a piecewise function to illustrate that the domain of integration changes with variable transformations, emphasizing that the definition of the function affects the domain.
  • Another participant suggests that the domain is invariant in a geometric sense, referring to a specific set of points, but acknowledges that changing coordinates alters how those points are represented.
  • A participant seeks clarification on how to denote the domain of integration, questioning whether it should be treated as an invariant geometric object or as a coordinate-dependent set.
  • One participant expresses uncertainty about the terminology used, attempting to clarify the concept of an "invariant geometric object" in the context of integration domains.
  • Another participant believes the earlier explanation provided in the thread is sufficient and suggests that further discussion may be unnecessary.
Participants express differing views on whether the domain of integration is invariant or dependent on the coordinate system used. The discussion remains unresolved, with multiple competing perspectives presented.
Participants highlight the complexity of defining the integration domain, noting that it may depend on the function being integrated and the coordinate system in use. There are unresolved questions regarding the implications of changing variables on the interpretation of the domain.
Barnak
I'm having an interpretation problem with the notation used in physics, under the integration sign.
What is the proper interpretation of the domain of integration symbol, on the integration sign ?
To be more precise, consider a function [itex]F(x)[/itex] of one or several variables. Its integral on a domain [itex]D[/itex] is simply
[itex]I = \int_D F(x) \, dx[/itex].
Now, we procede to a change of variables : [itex]x \rightarrow x' = h(x)[/itex], so the function is now a new function of the new variables : [itex]F(x) \rightarrow G(x')[/itex]. Of course, the integral above gives the same number, but the limits of integration have to change to adapt to the new variables. We can write :
[itex]I \equiv \int_{D'} G(x') \, dx'[/itex].
My question is this : is the symbol [itex]D[/itex] on the integration sign actually an invariant, so [itex]D' \equiv D[/itex] ? Or is it a representation of the values that the variables are taking under the integral (so [itex]D' \ne D[/itex]) ?
In other words : do the domain of integration [itex]D[/itex] change with the coordinates transformation ?
In general, D and D' will represent different sets of numbers, so they are different subsets of the real number line.
So you're saying that [itex]D[/itex] isn't invariant : it's a representation of the values taken by a given set of variables (coordinates) ?
I still have doubts on this. For example, when we define a surface integral like this :
[itex]I = \int_{\mathcal{S}} {\bf A} \cdot d{\bf S}[/itex],
the symbol [itex]\mathcal{S}[/itex] is both the domain of integration of the integral and the absolute surface in 3D space on which the integration is performed. So this implies that the domain [itex]D[/itex] is invariant. This is what puzzles me !
Why do you think that a domain of integration must be invariant if you change the variable ?
Obviously not ! The domain of integration depends on the way that the function is defined.
For example, consider the function F(x)=a if -1<x<1 and F(x)=b elsewhere.
Let x=x'/2 so, F(x)=F(x'/2)=G(x') then G(x')=a if -2<x'<2 and G(x')=b elswhere.
Integrating F(x) on D=[-1,1] is the same as integrating G(x') on D'=[-2,2]
If you integrate G(x') on [-1,1] instead of [-2,2], you will obtain a different result.
Similary in 3D.
A surface (S) can be defined on many ways, i.e. with many different equations, by change of variables, or by change of coordinates (Cartesian, polar, ...) or by change of axes system. For each one of these definitions of the same surface with same border, the equations which characterize the border are different. If we integrate on (S), of course we have to consider the convenient related equation of the border, not another one, hense not always the same equation (but the border is the same on geometical viewpoint).
It is "invariant" in the sense that it refers, geometrically, to a specific set of points. When you change variables, you are changing "coordinates" and how those points are given in the new coordinates will change.
But then how should we indicate the domain below the integral sign ? As an invariant geometric object ([itex]D' \equiv D[/itex]), or as a coordinates relative set ([itex]D' \ne D[/itex]) ?
Of course, the integration limits are changing with the coordinates change (obvious !), but those limits aren't the same as indicating "[itex]D[/itex]" below the integration sign.
the question can be asked differently : What is an integration domain ? Is it an invariant geometic object on which the integration is performed, or is it the set of values of the integration variables ? I suspect it is the first one.
Barnak, could you tell us what you mean by "invariant geometrical object"?
Well, I badly expressed myself (sorry, English isn't my primary language).
I mean an "absolute" or coordinates independent object, like a surface in 3D space. Or a region [itex]D[/itex] in space.
To me, it is almost clear (? not sure yet) that the integration domain [itex]D[/itex] is a coordinates independent thing. Of course, to explicitely perform the integration, we need some coordinates and specify the limits on the integral sign. But there should be a difference between the following two notations :
[itex]\int_{D} F \, d^3 x = \iiint_{-\infty}^{+\infty} F(x,y,z) \, dx \, dy \, dz.[/itex]
Hi !
The explanation of HallsofIvy (post #5) is clear and suffisant. This should close the discussion. The question was pertinent and the answer is obvious.
It seems to me that it would therefore be misplaced to discuss ad infinitum the gender of angels.
  • · Replies 29 ·
