What are the critical numbers for g(x) = x^2 + 2x^(2/3) on [-2,2]?
  • Thread starter Thread starter jzq
    Absolute Extrema
The discussion revolves around finding the critical numbers for the function g(x) = x^2 + 2x^(2/3) on the interval [-2, 2]. Participants are exploring the implications of the derivative and its behavior across the specified domain.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the derivative g'(x) = 2x + (4/3)x^(-1/3) and express confusion about finding critical numbers, particularly regarding the behavior of the function for negative x values. Questions arise about the validity of complex numbers in this context and the criteria for determining maxima and minima.
There is an ongoing exploration of the derivative's implications, with some participants suggesting that critical points should be found by setting the derivative to zero, while others emphasize the need to evaluate the function at the endpoints of the interval. The discussion reflects a mix of interpretations regarding the nature of the critical points and the role of complex numbers.
Participants note that the derivative is not defined at x = 0, raising questions about how to handle this point along with the endpoints of the interval. There is also mention of the function's evenness and its implications for the extrema.
jzq
The function is:
[tex]g(x)=x^2+2x^\frac{2}{3}[/tex] on [-2,2]
So far I got the derivative as:
[tex]g'(x)=2x+\frac{4}{3}x^{-\frac{1}{3}}[/tex]
Now, I am stuck at finding the critical #s. I need help.
Wont that be complex when x is negative? How are you going to maximize that?
Is there an easier method?
I mean won't the answer have an imaginary part. What criteria are you using to maximize the imaginary part of the answer?
Example:
[tex] {\left( -2 \right) }^{\frac{2}{3}} = -0.793 + 1.37473\ I[/tex]
Imaginary? Ooh...I don't think it's suppose to get that complicated. At least not yet. Call me slow but we definitely haven't learn that yet. The way I was taught to find critical numbers was set the derivative equal to zero. The cube root makes it difficult for me. How would you simplify the derivative. Once I know that I'll probably be able to take it from there.
I'm not sure what you mean when you say criteria. If the interval is what you mean then here: [-2,2]
Well:
[tex] g'(x) = 2 x + \frac{4}{3}x^{-\frac{1}{3}} = 0[/tex]
Take [itex]\frac{4}{3}x^{-\frac{1}{3}}[/itex] to the other side of the equation.
use:
[tex] x^{-1}=\frac{1}{x}[/tex]
Solve for x
Edit:
Does this make sense?
So basically you mean: (correct me if I'm wrong)
[tex]2x=-\frac{4}{3x^\frac{1}{3}}[/tex]
Then divide that by 2? Ok, obviously I'm not very bright in math. Then how would you move the x from [tex]3x^\frac{1}{3}[/tex] over?
Now multiply both sides by [itex]x^\frac{1}{3}[/itex]...
Also, since you're looking for global extrema on a closed interval, you need to test the endpoints.
--J
Yes that is right.
I am being stupid and time to go to bed.
jzq said:
The function is:
[tex]g'(x) = 2x + \frac {4} {3} x^{-1/3}[/tex]
The function g(x) has the following extrema on the Interval [-2, 2]:
Absolute and Relative Minimum at x=(0) where g(0)=(0)
Absolute Maximum at x=(-2) where g(-2)=(7.17)
Absolute Maximum at x=(+2) where g(+2)=(7.17)
Note: g'(x) has NO real values on [-2, 2] where g'(x)=(0). All maxima and minima must be determined "graphically" by computing values of g(x) on [-2, 2].
Thanks Xanthym and everyone else!
How are you geting this to be real?
Clarify:
[tex] (-2)^{-\frac{2}{3}} \in C[/tex]
Where C is the field of Complex numbers.
[tex]\ \ \ \ g(x) = x^{2} + 2x^{2/3}[/tex]
[tex]\ \ \ \ g(-2) = (-2)^{2} + 2((-2)^{2})^{1/3} = (7.17)[/tex]
Why is that valid over:
[tex] g(-2) = (-2)^2 +2((-2)^\frac{1}{3})^2[/tex]
Not that you are claiming such. But if you perform the reverse operation:
[tex] (((-2)^2)^\frac{1}{3})^\frac{3}{2}=2 \ne -2[/tex]
I thought the root was not considered valid when this was true.
edit:
never mind the ^1/2 takes care of both
An appropriate argument to determine the extrema is to observe the properties of the derivative g'(x).
[tex]g'(x) = 2x + \frac{4}{3x^{1/3}}[/tex]
Note that the derivative is not defined at x = 0, so therefore it is important to test the point x = 0 as well as the endpoints of the interval, x = ±2.
Also, for [itex]-2 \leq x < 0[/itex], g'(x) < 0. For [itex]0 < x \leq 2[/itex], g'(x) > 0. This implies that local maxima will be found at the endpoints, and the absolute maximum will be one or both of them. It is sufficient to show that g(x) is even, i.e. g(x) = g(-x) to determine that the absolute maximum will be attained at both endpoints. Additionally, the monotonicity of the derivative in the two regions as well as the continuity of g(x) implies that the absolute minimum will be found at x = 0.
There is nothing that needs to be done graphically in this problem.
--J
There's no imaginary part here.All complex #-s involved are real.What are you dreaming about...?
Daniel.
There are complex numbers which satisfy (-2)^(-2/3). I was just tired and was ignoring the real answers.
I blame my lack of sleep myself.
  • · Replies 16 ·
