Calculate Volume of Solid Rotated about y=4
  • Thread starter Thread starter ProBasket
    Solid Volume
The discussion revolves around calculating the volume of a solid obtained by rotating the region bounded by the curves y=x^6 and y=1 about the line y=4. Participants express confusion regarding the setup and application of the disc method versus the washer method in this context.
  • Mixed
  • Participants explore the correct axis of rotation and the definition of the radius for the disks formed during the rotation. There are attempts to clarify the setup of the integral and the bounds for the volume calculation.
Some participants have provided guidance on the correct interpretation of the problem, suggesting the use of the washer method and clarifying the roles of the outer and inner radii. However, there remains some uncertainty about the application of the disc method and the specific calculations involved.
There are mentions of constraints related to the methods learned in the course, with some participants indicating that they have not yet covered the washer method, which may limit their ability to fully engage with the problem as presented.
ProBasket
Find the volume of the solid obtained by rotating the region bounded by the given curves about the specified axis.
y=x^6
y=1
about y=4
here's what i done:
[tex]x=(y)^{1/6}[/tex]
[tex]A(y) = pi(4-(y)^{1/6})^2[/tex]
[tex]\int_0^{1} pi(4-y^{1/6})^2 dy[/tex]
anyone know what i have done wrong? this section really confuses me.
In which plane are the circles? x-y, x-z,y-z? The radius of the circle is defined by what?
x-y
"The radius of the circle is defined by what?"
are you asking me or telling me to post more about the question? cause that's the whole question.
If the equations are defined in the x-y plane then the circles have to be in the x-z or x-y plane. When you rotate around y=4 you are rotating into the z axis.
y=4 and y = 1 are horizontal lines in the y vs x plane. Try visualizing the problem keeping this in mind.
Edit:
Does that help?
The point of the question about the radius of the circles (formed when rotating the figure) is that since you are rotating around the line y= 4, the radii are in the y direction, not x!
y=x^6
y=1
about y=4
here's what i done:
You're rotating around the wrong axis. You're rotating around x=0, not y=4. Try the washer method instead of the disc method and rotate around y=4.
this section I'm doing is all about the disc method, we haven't learned the washer method yet(if possible), so can you please help me with the disc method. i see that i was rotating about the x=0 axis, how would i change it to rotate it around the y=4 axis?
i'm thinking...
[tex]\int_0^{1} pi*(4-x^6)^2 dx[/tex]
That is exactly what every one has been doing! Rotating around the y= 4 axis just means that the radius of each disk is measured by y- 4, not x.
hmm then what am i doing wrong? after integrating that function i get 1359/91*pi. only thing that i can think of getting incorrectly is the bounds which looks correct because i plugged it into my calculator.
y=x^6
y=1
about y=4
here's what i done:
Ok, first of all, the bounds. You set the two equations equal to each other to and solve.
[tex]x^6=1[/tex] The answers to this are (-1,1)...QED: These are your bounds.
The volume using the disc\washer method is found by:
[tex]V = \pi\int_{a}^{b}R^2-r^2dx[/tex] (dx in this case!)
R is the outer radius and r is the inner radius.
Ok. So, since you are revolving about the line y=4 the outer radius becomes (4-x^6)^2 and the inner radius is (4-1)^2.
Alright, finally let's set it up.
[tex]V = \pi\int_{-1}^{1}(4-x^6)^2-(3)^2 dx[/tex]
I'll leave to you to figure that out.
:smile:
awesome, thanks for the help. the only thing that i don't get is how you got an inner radius of 3?
4-1=3... the axis of rotation is y=4, so the area you're rotating is 4-1
  • · Replies 19 ·
  • · Replies 16 ·
  • · Replies 21 ·
  • · Replies 16 ·
