Help designing analog filter designs for an audio activated 8x8x8 LED cube
This discussion focuses on designing an analog filter system for a music visualization project using an 8x8x8 LED cube. The user aims to filter, amplify, and add DC bias to a +/- 1.5V audio signal from an MP3 player to produce three output signals: lowpass, bandpass, and highpass, with specific cutoff frequencies. The design utilizes LT1632 dual op-amps, resistors, and 100nF capacitors, and the user has attempted to use TI's FilterPro software and LTSpice for simulation. The recommended approach is to combine the amplification and biasing steps into a single op-amp stage and consider using a switching regulator for a negative supply rail.
  • Understanding of analog signal processing
  • Familiarity with op-amp circuit design
  • Knowledge of filter design principles (lowpass, bandpass, highpass)
  • Experience with simulation software like LTSpice
  • Research "level shifting op amp circuits" for combining amplification and biasing
  • Explore active filter designs that can output lowpass, bandpass, and highpass signals simultaneously
  • Investigate switching regulator modules for creating negative supply rails
  • Review the design files for the three filters to troubleshoot and optimize the circuit
Electronics enthusiasts, audio engineers, and hobbyists working on LED visualization projects or analog signal processing applications.
mp4nerd
I am working on designing a music visualization system using LEDs. I would like to create an analog design that uses op amps to filter, amplify, and add DC bias to an audio signal so it can be read into the A/D of a 5V microprocessor. The input signal is a +/- 1.5V volt audio signal coming from an MP3 player. From this signal I need to produce three output signals. This means that I need to design three filters (a lowpass, a bandpass, and a highpass). These filters also need to amplify and bias the input signal so it will be a 0 to 5V signal that can be read by the processor's A/D at the maximum resolution. So basically what I have pictured is to first bias the signal, then amplify it, then filter it:
MP3 Player Audio signal --> Bias --> Amplify --> Filter --> uP
I am familiar with building filters with amplification, but I am not sure about the correct way to go about adding a DC bias to the filters with amplification.
Lowpass (bass range): cutoff f @ ~500 Hz
Bandpass (mid range): center f @ ~2250 Hz
Highpass (high range): cutoff f @ ~4kHz
The parts I have available for use are: LT1632 dual op-amps, resistors, 100nF capacitors
Measuring the output signal from the iPhone: V(peak-to-peak): ~2.85V centered around 0V
Required Gain: ~1.75
Available Power supply units: +5V and +12V DC
I've tried designing these filters by hand, and using TI's FilterPro software, however I have not been able to achieve the DC bias affect. I have been simulating the filters using LTSpice. I have the design files for the three filters though if it would help in describing my current problem. Any help in this area would be greatly appreciated.
Change that to
MP3 Player Audio signal --> Filter --> Amplify --> Bias --> uP
You should be able to combine the Amplify and Bias steps into one op-amp stage. Look up "level shifting op amp circuits" if you are still stuck.
Hi mp4nerd, http://img96.imageshack.us/img96/5725/red5e5etimes5e5e45e5e25.gif
It seems that you are provisioned with only single ended power supplies. Rather than modify circuits to power op-amps off a single ended supply, it may be more expedient for you to employ a switching regulator module to produce a negative supply rail for the op-amps in your filter, amplifier, etc. There exist active filter designs that can provide all of LP, BP, and HP outputs from the one circuit, e.g., http://mysite.du.edu/~etuttle/electron/elect65.htm[/color]
Follow this active filter stage with a separate buffer stage incorporating the required gain and adding some DC bias there.
Good luck with your colourful project! http://img571.imageshack.us/img571/7470/rainbowf.gif
  • · Replies 29 ·
  • · Replies 17 ·
9K
10K
