Energy in destructive interference.
In the context of two pulses in a stretched string interfering destructively, when the pulses collide, they completely cancel each other out if their amplitudes are equal. This results in a moment where the total energy of the system becomes zero, as the kinetic energy (KE) and potential energy (PE) are both absent during complete destructive interference. The key takeaway is that at the moment of interference, the energy does not convert into potential energy; rather, it is temporarily non-existent.
  • Understanding of wave mechanics and interference patterns
  • Knowledge of kinetic energy and potential energy concepts
  • Familiarity with the behavior of waves in a stretched medium
  • Basic principles of energy conservation in physical systems
  • Study the principles of wave interference in detail
  • Learn about energy conservation in oscillatory systems
  • Explore the mathematical representation of wave functions and their interactions
  • Investigate real-world applications of destructive interference in physics
Students studying physics, particularly those focusing on wave mechanics, educators teaching energy concepts, and anyone interested in the dynamics of wave interactions in physical systems.
AlchemistK
What happens to the kinetic energy of the system when two pulses interfere destructively?
Exact Question:
Two pulses in a stretched string whose center are initially 8 cm apart are moving towards each other as shown in the figure(Attached). The speed of each pulse is 2 cm/s. After 2 sec the total energy of the pulse is
a)zero
b)purely kinetic
c)purely potential
d)partly KE and partly PE
When two pulses collide, they interfere, either destructively or constructively, depending on their phase difference. In this case they will interfere destructively and if the amplitudes are equal, they will completely cancel each other out.
But where did the energy go?
What exactly goes on at the time of the interference? Does the energy temporarily get converted into potential energy?
Keep in mind that two things can be happening to the string at any time:
(1) it can be stretched, i.e. displaced from the equilibrium position
(2) it can be in motion, i.e. moving up and down.
Thinking about these questions should help you get the answer:
Which one of the above is associated with potential energy?
Which of the above goes with kinetic energy?
And finally,
Is one of the above definitely not present at the moment there is complete destructive interference?
Answering that last question should lead you to the answer.
  • · Replies 21 ·
  • · Replies 20 ·
  • · Replies 71 ·
12K
