New Reply
Electrostatics: Surface charge density-numerical solution
Share Thread Thread Tools
Dec2-12, 04:27 AM   #1
Hi, I'm very new here, 10min old, but the problem with my knowledge, or better, lack there of, at this time is very hard, so I need help. I am trying to numerically calculate a certain electrostatic problem (attached an image "prob.jpg" to clarify). I have a disk at potential V0, and with this equation
[itex]V(\rho,\varphi)=\frac{1}{4\pi\epsilon_0}\int\int \frac{\sigma(\rho',\varphi')\rho'd\rho'd\varphi'}{ \sqrt{\rho^2+\rho'^2 - 2\rho\rho'cos(\varphi-\varphi')}} (1)[/itex]
I'm trying to then numerically calculate for σ (attached 2 images "disk.png","charge_on_disk.png" to clarify), this integral equation. So I basically get an equation A*σ=b (A-matrix, σ,b-vectors). As for [itex] A_{ij} [/itex] where [itex]i \neq j[/itex], i think there should be no problem with equation (1), but what about [itex]A_{ii}[/itex], what is.. or how should I set up the equation for these terms, since if I used the same equation (1), I would get [itex]\frac{something}{0}[/itex]. I have no idea where to even start the thought process, to go about setting up the equation.
For the sake of being brief, I will stop, and ask that if I have made anything unclear just say so and I will try to explain further(better).
Thank you.
EDIT: I tried setting all the terms to 1 [itex]A_{ii}=1[/itex] and the resulting graph seems correct, but that's just guess work, I have no basis for setting it to a constant 1.
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> A quantum simulator for magnetic materials
>> Atomic-scale investigations solve key puzzle of LED efficiency
>> Error sought & found: State-of-the-art measurement technique optimised
New Reply
Tags
charge, electrostatics, mom, numerical, surface
Thread Tools
Similar Threads for: Electrostatics: Surface charge density-numerical solution
Thread Forum Replies
VOLUME charge density from SURFACE/LINE charge density?? Classical Physics 9
Electrostatics - finding the total charge of a sphere with varying charge density Introductory Physics Homework 1
Force on a point charge due to constant sphere surface charge density. Advanced Physics Homework 2
electrostatics... charge density... Introductory Physics Homework 3
Electrostatics - Charge Density Classical Physics 3
