Plotting Function 1/(X^3 + X^2 +1) in MATLAB
  • Context: MATLAB
  • Thread starter Thread starter Electro
    Matlab Plotting
The discussion focuses on plotting the function 1/(X^3 + X^2 + 1) in MATLAB, highlighting an error due to division by zero at X = -1.4656. The user seeks assistance in visualizing this function, which is undefined at certain points. A step-by-step approach is provided, including defining the range, number of points, and using a loop to calculate values while handling potential errors. This method ensures that the plot can be generated without encountering undefined values.
  • Understanding of MATLAB syntax and functions
  • Knowledge of polynomial functions and their properties
  • Familiarity with plotting techniques in MATLAB
  • Basic error handling in programming
  • Learn how to implement error handling in MATLAB functions
  • Explore MATLAB's plotting functions for advanced visualizations
  • Study the concept of limits and discontinuities in mathematical functions
  • Investigate MATLAB's vectorization techniques to optimize calculations
Mathematics students, MATLAB users, and engineers looking to visualize complex functions and handle undefined values in their plots.
Electro
Hi there,
I have a simple function and I want to plot it in MATLAB but i get an error.
Maybe someone can help. The function is of the type 1/(X^3 + X^2 +1)
I can plot a polynomial but I have no idea about the function above.
Thnx
Electro said:
Hi there,
Thnx
Your function is UNDEFINED (Illegal) at X=(-1.4656) because the denominator becomes 0 at this point which involves division by zero. If your graph includes this X value, that's probably the problem.
You could do the following:
1. Decide on your range xmax, xmin
2. Decide on the number of points you want to plot (say N=1,000)
3. Declare an Axis vector with the axis points and a Y = zeros(1,N) vector to receive the results of the calculation
4. Use a loop to perform the calc y = ... from xmin to xmax in steps (xmax - xmin)/N and populate the Y vector. Include a check which says if the calc gives an error, put zero in that cell.
5. Plot Y vs Axis.
Others with more Matlab experience may have a much better solution but let me know if you want me to knock together some useable code.
