What is the Velocity Ratio in an Elastic Collision?
The discussion revolves around an elastic head-on collision involving two objects, where one object is initially at rest. The problem specifically addresses the calculation of the velocity of the incident object after the collision, given the mass ratio of the two objects.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants discuss the use of equations related to elastic collisions, particularly focusing on the conservation of momentum and the relationship between relative speeds before and after the collision. There is uncertainty about how to derive the final velocity using the given mass ratio.
Some participants have provided equations and attempted to manipulate them to express the final velocities in terms of the initial velocity. There is an acknowledgment of the complexity involved in using the mass ratio to find the velocities, and some participants express confusion about the process.
The problem is constrained by the requirement to express the final velocities in terms of the incident velocity, and participants are working within the framework of elastic collision principles.
lookitzcathy
Okay, so my homework question is:
5) An object makes an elastic head-on collision with another "target" object which is initially at rest. If the ratio of incident mass over target mass is 0.5333, what is the velocity of the incident object after the collision in multiples of its incident velocity? Give the result with the appropriate sign taking the incident velocity as positive.
Would any of ya'll be kind enough to help me solve this problem?! Thanks a bunches. :blushing:
Use the fact that in an elastic collision the relative speeds are the same before and after the collision (speed of approach = speed of separation after collision).
[tex]m_1v_{1i} = m_1v_{1f} + \frac{m_1}{.5333}v_{2f}[/tex]
and:
[tex]v_{1i} - 0 = v_{1f} - v_{2f}[/tex]
Two equations and two variables should be all you need to express an answer in terms of [itex]v_{1i}[/itex]
AM
and:
AM
hey... yea, i got that equation too... but I'm still unsure of how i will be able to find the velocity by just knowing the "ratio" of the incident mass over target mass. :confused: sigh*
(1)[tex]m_1v_{1i} = m_1v_{1f} + \frac{m_1}{.5333}v_{2f}[/tex]
and:
(2)[tex]v_{1i} - 0 = -(v_{1f} - v_{2f})[/tex] (I forgot the minus sign before)
Substitute expression for v1f from (2) into (1):
[tex]m_1v_{1i} = m_1(v_{2f} - v_{1i} + \frac{1}{.5333}v_{2f})[/tex]
[tex]2m_1v_{1i} = m_1v_{2f}(1 + \frac{1}{.5333})[/tex]
[tex]v_{2f} = v_{1i}\frac{1.0666}{1.5333} = .6956v_{1i}[/tex]
from (2):
[tex]v_{1f} = (1 - .6956)v_{1i} = .3044v_{1i}[/tex]
AM
o wow i got it... thank you so much!
  • · Replies 16 ·
