Proving the Summation Formula for 1/(n(n+1)) Using Mathematical Induction
  • Context: Undergrad
  • Thread starter Thread starter knowledgeSeeker
    Induction Proof
The discussion focuses on proving the summation formula for the series \( \frac{1}{n(n+1)} \) using mathematical induction. Participants explore the basis and inductive steps necessary to establish the validity of the formula for all integers \( n \geq 1 \).
  • Homework-related
  • One participant seeks assistance in proving that \( \sum_{i=1}^{n} \frac{1}{i(i+1)} = \frac{n}{n+1} \) for all integers \( n \geq 1 \), outlining the basis step for \( n = 1 \).
  • Another participant suggests that the next step involves assuming \( P(k) \) is true and then adding the next term to both sides to reach \( P(k+1) \).
  • A third participant defines \( S_k \) as the sum up to \( k \) and expresses \( S_{k+1} \) in terms of \( S_k \) and the next term in the series, questioning how to simplify the resulting expression.
  • A later reply claims to have proved that both sides equal \( \frac{k+1}{k+2} \), asserting that the property holds for \( n = k + 1 \).
Participants generally agree on the steps involved in the proof by induction, but the discussion does not reach a consensus on the finality of the proof, as it is based on individual contributions and interpretations.
Some participants' contributions involve assumptions about the validity of earlier steps without fully resolving all mathematical details, particularly in the simplification of expressions.
knowledgeSeeker
Need help with proof by mathematical induction that (1/(1*2)) + (1/(2*3)) + ... + (1/(n(n+1)) = (n/(n+ 1)) for all integers n >= 1.
Basis step: for n = 1: (1/(1*2)) = 1/2 and (1/(1+1) = 1/2, hence property is true for n = 1.
Inductive step: want to show that for alll integers k >= 1, if n = k is true then n = k + 1 is true. How do I prove? Believe I want to show (1/(1*2)) + (1/(2*3)) + [1/((k+1)((k+1)+1)] = [(k + 1)/((k+1) + 1)], but how??
Thank you for any suggestions.
So you have shown that P(1) is true. Now you want to show that if you assume that P(k) is true, it follows that P(k+1) is true. So first write the expression for P(k), which you assume to be true. Then add the next number in the series (to both sides), and see if you can rearrange the expression on the right side into the form that you are trying to prove.
Let Sk= 1/(1*2)+ 1/(2*3)+ ...+ 1/(k(k+1)), the sum for n= k
Then S(k+1)= 1/(1*2)+ ...+ 1/(k)(k+1)+ 1/((k+1)((k+1)+1)= Sk+ 1/((k+1)(k+2))
By your "induction hypothesis", Sk= k/(k+1).
What is k/(k+1)+ 1/((k+1)(k+2)) ?
Thank you. Proved both sides = (k+1)/(k+2). Hence, true for n = k +1 and since both basis and inductive steps true, true for all n >= 1. :smile:
  • · Replies 29 ·
