How Does the Clausius-Clapeyron Equation Explain Temperature Changes in Liquids?
  • Context: Graduate
  • Thread starter Thread starter Reshma
    Clausius-clapeyron
The discussion centers on the Clausius-Clapeyron equation and its implications for temperature changes in liquids, particularly in the context of phase transitions and thermal equilibrium. Participants explore the physical significance of the equation and its applications in low-temperature physics.
  • Experimental/applied
  • One participant presents the Clausius-Clapeyron equation and asks about its physical significance.
  • Another participant elaborates on the equation, explaining that when a liquid and vapor are in thermal equilibrium, an increase in volume leads to more liquid turning into vapor, which draws heat from the liquid and decreases its temperature.
  • A later reply provides an example from low-temperature physics, noting that the principle is used with liquid helium and nitrogen to achieve temperatures below their normal boiling points, explaining that the highest energy helium molecules leave the liquid, resulting in a decrease in temperature.
Participants generally agree on the application of the Clausius-Clapeyron equation to explain temperature changes in liquids during phase transitions, but there is no explicit consensus on all aspects of its significance or implications.
The discussion does not resolve potential limitations or assumptions inherent in the application of the Clausius-Clapeyron equation, such as the dependence on specific conditions of pressure and temperature.
Readers interested in thermodynamics, phase transitions, and low-temperature physics may find this discussion relevant.
Reshma
The Clausius-Clapeyron equation is given by:
[tex]\frac{dP}{dT}=\frac{LJ}{T(V_2-V_1)}[/tex]
[itex]dP[/itex] is the change in pressure
[itex]dT[/itex] is the change in temperature
[itex]L[/itex] is the Latent heat of fusion/vaporisation
[itex]T[/itex] absolute temperature of substance
[itex]V_2-V_1[/itex] is the change in volume
[itex]J[/itex] is heat constant
What is the physical significance of this equation?
Science news on Phys.org
What, no replies so far!
When a liquid and vapour are in thermal equilibrium in a closed volume at a certain temperature, and the volume is increased slightly, some more liquid turns to vapour. Since the liquid has a latent heat (energy just required to break molecular bonds of liquid) the heat has to be drawn from the liquid so the temperature of the liquid/vapour decreases. (the opposite effect when the volume decreases - some vapour turns to liquid and the temperature increases). The Clausius-Clapeyron equation shows the relationship between a change in volume and the rate of change of vapour pressure with temperature.
AM
Thank you very much, sir!
Example
Anderw has described it correctly. Here is an exmple from a lab experience. Those who work in lowtemperature physics employ Liq.He and N2 and make use of this principle to reach temp. below the (normal) boiling point of these liquids. For example. Liq. He4 boils at 4.2K and by pumping over He4 vapour, one can attain temperature as low as 1K ! Said in a crude fashion, this means the He4 molecules having the highest Kin.Energy leavs the liquid surface making the total temp to decrease.
  • · Replies 19 ·
