Will an Astronaut Float at the Positional Median Between Earth and Moon?
The discussion centers on whether an astronaut positioned at the median point between the Earth and the Moon would experience a state of weightlessness similar to that of a person in free fall, due to gravitational influences from both celestial bodies. The scope includes conceptual reasoning about gravitational forces and their effects on an object in space.
  • One participant suggests that an astronaut at the positional median would float as if unaffected by gravity, similar to an elevator in free fall.
  • Another participant counters that the Earth's stronger gravitational pull would dominate, pulling the astronaut toward Earth, despite the Moon's influence.
  • A third participant questions the definition of "positional median," proposing two interpretations: halfway between the Earth and Moon or the point of equal gravitational force from both bodies. They note that if the astronaut were momentarily motionless at the latter point, there would be no net gravitational force, but this condition would not be stable due to the relative motion of the Earth and Moon.
  • A link to related information about Lagrange Points is provided, suggesting further exploration of gravitational balance in space.
Participants express differing views on the astronaut's experience at the median point, with no consensus reached on whether weightlessness would occur or how gravitational forces would interact.
The discussion highlights the ambiguity in the term "positional median" and the assumptions regarding the astronaut's motion and the relative positions of the Earth and Moon.
evthis
If an astronaut is located close to the positional median between the Earth and its moon, will the astronaut float around as if it was not being effected by gravity for the same reason that a person in an elevator in free fall would float around being unable to use a measuring device to calculate gravitational pull?
Astronomy news on Phys.org
I don't think so. What'll happen is the Earth, with it's greater gravity, will pull the astronaut toward Earth. Of course the Moon's gravity will affect the astronaut, but the Moon's gravity isn't strong enough for what you have in mind.
Anyone else?
The "positional median"?? Do you mean halfway between (in which case the Earth's gravity would be much greater) or the point at which the Earth's gravitational force and the moons are equal?
If you mean the latter AND assume the astronaut is motionless (momentarily) with respect to the Earth and the moon, then there would be no net gravitational force on the astronaut. However, that won't last long since Earth and moon are moving relative to one another!
related info...LaGrange Points
http://www.physics.montana.edu/faculty/cornish/lagrange.html
  • · Replies 33 ·
  • · Replies 18 ·
  • · Replies 20 ·
  • · Replies 51 ·
