Can overdrive voltage never be less than zero?
  • Thread starter Thread starter mnvaughn
    Voltage Zero
The discussion centers on the concept of overdrive voltage (Vov) in field-effect transistors (FETs), specifically addressing whether Vov can be less than zero. The threshold voltage (Vt) is established at +1V, and the calculations show that with Vgs at 0V, Vov results in -1V, indicating the transistor is not turned on. For NMOS transistors, Vov must be greater than zero for the device to operate, while for PMOS transistors, Vov being less than zero is acceptable. The discussion clarifies that Vov being negative means the NMOS is OFF, while a PMOS would be ON under similar conditions.
  • Understanding of field-effect transistors (FETs)
  • Knowledge of threshold voltage (Vt) and gate-source voltage (Vgs)
  • Familiarity with NMOS and PMOS transistor operation
  • Basic electrical engineering principles related to voltage and current flow
  • Study the operation principles of NMOS and PMOS transistors
  • Learn about threshold voltage (Vt) and its significance in FETs
  • Explore subthreshold operation and its applications in modern electronics
  • Investigate the effects of gate-source voltage (Vgs) on transistor behavior
Electrical engineers, students studying semiconductor devices, and professionals involved in circuit design and analysis will benefit from this discussion.
mnvaughn
I had a test recently and one of the problems was pretty basic. It gave you a table with the voltages at the gate, source, and drain of the device. Vt (Threshold voltage) was also provided, which was +1V. From there we were supposed to find Vgs, Vov(Overdrive voltage), Vds and the region of operation of the device. So for one part of the table I was provided with Vs (voltage at the source) is +1V, Vg (voltage at the gate) is +1V, and Vd (Voltage at the drain) is +2V. I know Vgs is Vg-Vs which in this case is 0V. And Vds is Vd-Vs which is +1V. However for Vov I got -1V which is solved by the equation (Vgs-Vt) so that would be 0-1=-1. This was wrong on my test. Does this mean the overdrive voltage can never be less than zero? Please help!
Vt is from gate voltage to source voltage. Vt=+1V means you need +1V at the gate RESPECTED to the source, NOT +1V respected to 0V.
In FET, you need to have Vgs exceed the Vt before the FET turns on. In your case, you correctly established that your Vgs=0V...Which is below the turn on threshold of Vt=1V. The transistor is not even turned on. That's all it means.
Another way to look at it is: Vt is the spec from the data sheet that you need Vgs to exceed Vt before the transistor turns on. This mean (Vgs-Vt) has to be slightly greater than 0V before the transistor turns on.
You are right in that Vov=Vgs-Vt
In your case, Vov would be negative.
What does that mean? Well, there are two cases to consider in general when Vov < 0 (although it is obvious that the transistor is NMOS since Vt > 0; unless, of course, it was given that |Vt|=1, then it is a PMOS and your answer would be wrong! Although the voltage levels at the gate and source doesn't make any resemblance with PMOS transistors bias conditions.):
1- If it was an NMOS (n-channel) FET, then it will be OFF.
It is clear because a positive potential at the gate (more than the threshold voltage when source is grounded) electrode is necessary to establish the electric field that will collect electrons from the source & drain, push free holes away from the substrate; that is, making a channel for current flow. So without the sufficient positive bias voltage you will have two back-to-back diodes in series between drain and source.
2- If it was a PMOS (p-channel) FET, then it will be ON .
It should be, since the condition Vov < 0 is necessary for this type of transistor; the physical reasoning is the total opposite of what is said above about NMOS.
I hope that helps :smile:
One important note:
What I said above, is not "entirely" true in that for values of Vgs less than but close to Vt, a small drain current flows. This is called Subthreshold operation.
It has rare (but a growing number) of applications, and usually we ignore this region of operation, for simplicity.
14K
32K
