How Long Until the Drink Reaches Room Temperature?
The discussion revolves around a problem involving heat transfer, specifically how long it takes for a drink composed of rum, coke, and ice to reach room temperature. The subject area includes thermodynamics and heat transfer principles.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants explore various methods of calculating heat transfer, including the use of equations related to heat flow and latent heat. Some question the assumptions made about room temperature and heat flow rates as the drink approaches that temperature. Others suggest practical experimentation as an alternative to theoretical modeling.
The discussion is ongoing, with participants offering different perspectives on the problem. Some have provided initial thoughts on modeling heat transfer, while others have raised questions about the assumptions and the nature of the inquiry itself. There is no explicit consensus on the approach to take.
Participants note the potential variability in results based on measurement accuracy and the nature of the question, suggesting that it may be more complex than it initially appears. There is also mention of the effects of evaporation and convection as factors in the heat transfer process.
rabiakhan.91
A person walks into a bar and orders a drink made of 1.5oz of rum, 4 oz of coke, and 3oz of ice. How long does it take the drink to reach the room temperature of 22 degC
q=mcΔT
q =mL where L is the latent heat of fusion
ΔQ/Δt=k(Tf-Ti)/L
First we calculate the amount of heat needed to change ice into liquid using q=mL
That will happen through conduction and radiation. Conduction through the walls of the glass and radiation from the top of the glass.
and then i am stuck! what to do next
If the room is assumed to be room temperature (duh), how does the heat flow rate from the glass change as the glass approaches room temperature?
Get 1.5 oz of ethyl alcohol, 4 oz of coke, 3 oz of ice. Mix in a glass cup. Get thermometer and watch. Record the time to get to room temperature. This process will be more accurate than trying to model the heat transfer.
Do you distinguish:
- reach room temperature within measurement error of some thermometer
and
- reach room temperature in exactly, per thermodynamic theory
What I'm getting at is that the question as given, without further qualification, seems like a trick question with an obvious answer.
I don't believe I've ever known a drink to last long enough to reach room temperature :biggrin:
I would start by assuming a cylinder of uniform temperature and convection as being the most dominate heat transfer mechanism and see where you end up time wise. Then perhaps you look at evaporation effects from the open glass. If that doesn't get you close things get ugly.
