PLz help me in this Corner Reflector Problem
  • Context: Undergrad
  • Thread starter Thread starter shaiqbashir
    Reflector
The discussion revolves around a problem related to the behavior of light when interacting with a corner reflector, which consists of three mutually perpendicular reflecting surfaces. Participants are exploring the principles of retroreflection and how a light ray is reflected back along a line parallel to its original direction after striking all three surfaces.
  • Homework-related
  • One participant requests assistance with a coursework problem involving a corner reflector and expresses urgency due to an upcoming test.
  • Another participant suggests that the problem has been adequately addressed in the relevant section of their coursework.
  • A third participant recommends searching for "retroreflection" in the index of the textbook as a potential resource.
  • A later reply describes the reflection process, indicating that the light's velocity components change sign upon each reflection, resulting in the final velocity being parallel and opposite to the original direction.
There is no consensus on the solution to the problem, as participants provide varying levels of assistance and suggestions without resolving the original query.
The discussion does not clarify specific assumptions about the geometry of the corner reflector or the initial conditions of the light ray. The explanation of the reflection process may depend on the definitions of the coordinate system used.
shaiqbashir
Hi!
Well can u help me in this problem. it is related to a device called Corner Reflector.
" A corner reflector is formed by three mutually perpendicular reflecting surfaces. Show that a ray of light incident upon the corner reflector (striking all three surfaces) is reflected back along a line parallel to the line of incidence.(Hint: Consider the effect of a reflection on the components of a vector describing the direction of the light ray). The Apollo mission placed this type of reflector on the surface of the moon in 1969."
Please help me in this problem, i just don't know how to solve it. i have only two days left for my test. Plz Help
"Thanks in advance"
I believe this coursework problem has been well-answered in the relevant section.
"Retroreflection," try finding it through the index of your text.
Just think about it. The light hits the "X" mirror (which is a 'square' facing down the X axis) and it's x velovity becomes -x. It hits the "Y" and its y velocity becomes -y, it hits the "Z" and its z velocity becomes -z.
So, in the end, it's velocity goes from x,y,z to -x,-y,-z. That velocity is parrallel and opposite the original one!
  • · Replies 50 ·
  • · Replies 34 ·
