Physical significance of Refractive index
The discussion centers on the physical significance of the refractive index (RI), exploring its implications in various fields such as petrology, optics, and electromagnetic theory. Participants examine the role of RI in light propagation, material interactions, and its mathematical representation.
  • Some participants note that refractive index is significant in identifying minerals in petrology based on their unique refractive indices.
  • Others explain that the refractive index indicates how quickly light travels through a medium and relates to the speed and wavelength of light in that medium.
  • It is mentioned that the refractive index is used to describe various optical phenomena such as reflection, refraction, and dispersion, and can be modeled using permittivity and permeability.
  • Some participants highlight that the refractive index is a complex quantity that includes a loss component, which can be significant in certain materials.
  • There is a discussion about the frequency dependence of the refractive index, particularly its relevance to phenomena like the greenhouse effect and light dispersion through prisms.
  • One participant suggests that the refractive index can be derived from classical electrodynamics under specific assumptions about electron behavior in atoms.
  • The Appleton Hartree equation is mentioned as a method to derive the complex refractive index for electromagnetic waves in plasma, relevant for ionospheric propagation predictions.
Participants express multiple competing views regarding the significance and implications of the refractive index, indicating that the discussion remains unresolved with no consensus reached.
Some claims depend on specific assumptions about the behavior of light and materials, and the discussion includes references to various models and equations that may not be universally accepted or understood.
mikeanndy
What is the physical significance of Refractive Index(RI) ?
Science news on Phys.org
Can you be more specific in your question? What exactly are you wanting to know?
well for work I have done in petrology ( study of minerals) refractive index is very significant because dofferent minerals can be identified by they refractive indicies
just one example :)
Dave
The refractive index relates how quickly light travels through a given medium. It's a the number by which you divide the speed of light in a vacuum to get the speed of light in the given medium. Or, the number by which you divide the wavelength of the light in a vacuum to get the wavelength of the light the given medium.
I'd recommend looking at the Wikipedia article:
http://en.wikipedia.org/wiki/Refractive_index
So when the light changes medium it changes speed. If the light beam approaches the interface between media obliquely, this change of speed gives rise to refraction: a change in the direction of travel of the beam. A very simple formula (see wikipedia article on refraction) links angles of the beam to the normal in the two media to the ratio of refractive indices of the media.
The refractive index is used in the continuum model of matter and parametrizes how matter interacts with electromagnetic radiation. The refractive index is used to describe reflection, refraction, dispersion, absorption, birefringence, and various nonlinear effects (Kerr, harmonic generation, self-phase modulation, etc.).
The refractive index can be 'split' into the permittivity and permeability, referring to how the material responds to either an electric or magnetic field, and can then be used to model additional material properties.
Refractive index is actually a complex quantity and it includes a loss component which may be significant in some materials.
Refractive index is not only complex, but depends on the frequency of the light for a given material. Generally, though, it's stated for yellow light (more precisely the doublet sodium D-line).
The fact that the refractive index depends on the frequency of light accounts for things such as the greenhouse effect, whereby a material (such as glass) can absorb certain wavelengths, but allows other wavelengths to pass through. It also accounts for a prism splitting the light up into it's different colours.
one can derive an expression for refractive index in classical electrodynamics if one assumes that electron is bounded to atom by a restoring force.
The Appleton Hartree equation derives the complex refractive index for EM waves in a plasma. Useful for predictions of Ionospheric Propagation using ray tracing methods, for example. It gives speed and loss in the medium.
  • · Replies 33 ·
